Problem with xvt terminal command on OpenMandrivaLx3.01
If you try to start an xvt terminal you get the error message “Unknown option ‘nofork’”
I think the /usr/bin/xvt script contains a bug.
Regards,
Albert
/usr/bin/xvt script launch default terminal in you environment. When in KDE it launches konsole with –nofork option but konsole doesn’t support it. So please could you may file a bug on bugzilla?
Bug 2159 has been created.
Hi, will fix it soon.
Fixed.
Thanks, I installed the update and the bug is fixed.
