Problem with Gearlever updating appimages
OpenMandriva Lx release 26.09 (ROME) Rolling for znver1
XFCE
I have gearlevel installed. I have only the Bitwarden appimage. I’ve tried to check it for updates in the gui launched from the menu. Nothing happens, just continues to spin gears. When I run the command <gearlevel --update Bitwarden> or <gearlevel --update *> it gives me the following errors:
File “/usr/bin/gearlever”, line 44, in
sys.exit(main.main(VERSION, pkgdatadir))
File “/usr/share/gearlever/gearlever/main.py”, line 225, in main
Cli.from_options(sys.argv)
File “/usr/share/gearlever/gearlever/Cli.py”, line 52, in from_options
getattr(Cli, name)(argv)
File “/usr/share/gearlever/gearlever/Cli.py”, line 115, in update
manager = UpdateManagerChecker.check_url_for_app(el)
File “/usr/share/gearlever/gearlever/models/UpdateManagerChecker.py”, line 44, in check_url_for_app
embedded_app_data = UpdateManagerChecker.check_app_embedded_url(el)
File “/usr/share/gearlever/gearlever/models/UpdateManagerChecker.py”, line 63, in check_app_embedded_url
readelf_out = terminal.sandbox_sh([‘readelf’, ‘–string-dump=.upd_info’, ‘–wide’, el.file_path])
File “/usr/share/gearlever/gearlever/lib/terminal.py”, line 43, in sandbox_sh
output = subprocess.run(cmd, stdout=subprocess.PIPE, stderr=subprocess.PIPE, **kwargs)
File “/usr/lib64/python3.14/subprocess.py”, line 555, in run
with Popen(*popenargs, **kwargs) as process:
File “/usr/lib64/python3.14/subprocess.py”, line 1039, in init
self._execute_child(args, executable, preexec_fn, close_fds,
pass_fds, cwd, env,
…<5 lines>…
gid, gids, uid, umask,
start_new_session, process_group)
File “/usr/lib64/python3.14/subprocess.py”, line 1990, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: ‘readelf’
Do you have an update source URL/Github/etc. entered for Bitwarden? Those have to be inputted manually.
Try this setup in GearLever’s update settings for Bitwarden. It works for me.
Thank you, I didn’t know a source had to be manually added for each appimage.
I added sources/file names for both Bitwarden and Discord, but unfortunately I’m getting the same error.
I’m trying to use appimages so I can avoid Flathub, but it seems I may have to use it regardless.
I have used the Flatpak for Bitwarden and currently use the one for Discord and have no complaints (though with Bitwarden I’ve found that I really only need the browser extension). Discord gets updated (with updates that you are not allowed to skip) that it’s really hard to keep anything but the Flatpak functional on Linux.
