Potential fix for error installing google-chrome
I’ve seen complaints that even after enabling the google-chrome repo, users can’t install the google-chrome-stable from it. dnf craps out with an error:
Last metadata expiration check: 0:01:34 ago on Wed 26 Feb 2025 09:23:41 PM EST.
Dependencies resolved.
 Package                                  Architecture               Version                               Repository                          Size
Installing:
 google-chrome-stable                     x86_64                     133.0.6943.141-1                      google-chrome                      111 M
Installing dependencies:
 gtk+3.0-common                           noarch                     3.24.48-2                             rolling-x86_64                     3.7 M
 lib64gdk3_0                              x86_64                     3.24.48-2                             rolling-x86_64                     415 k
 lib64gtk3_0                              x86_64                     3.24.48-2                             rolling-x86_64                     3.0 M
 lib64tinysparql                          x86_64                     3.8.2-1                               rolling-x86_64                     292 k
Transaction Summary
Install  5 Packages
Total download size: 118 M
Installed size: 391 M
Is this ok [y/N]: y
Downloading Packages:
(1/5): google-chrome-stable-133.0.6943.141-1.x86_64.rpm                                                              68 MB/s | 111 MB     00:01
(2/5): lib64gdk3_0-3.24.48-2-omv2590.x86_64.rpm        69 kB/s | 415 kB     00:06
(3/5): lib64gtk3_0-3.24.48-2-omv2590.x86_64.rpm        675 kB/s | 3.0 MB     00:04
(4/5): gtk+3.0-common-3.24.48-2-omv2590.noarch.rpm        618 kB/s | 3.7 MB     00:06
(5/5): lib64tinysparql-3.8.2-1-omv2490.x86_64.rpm        56 kB/s | 292 kB     00:05
Total        10 MB/s | 118 MB     00:11
google-chrome        95 kB/s |  19 kB     00:00
You can remove cached packages by executing 'dnf clean packages'.
  File "/usr/sbin/dnf", line 57, in <module>
    main.user_main(sys.argv[1:], exit_code=True)
  File "/usr/lib/python3.11/site-packages/dnf/cli/main.py", line 208, in user_main
    errcode = main(args)
  File "/usr/lib/python3.11/site-packages/dnf/cli/main.py", line 67, in main
    return _main(base, args, cli_class, option_parser_class)
  File "/usr/lib/python3.11/site-packages/dnf/cli/main.py", line 106, in _main
    return cli_run(cli, base)
  File "/usr/lib/python3.11/site-packages/dnf/cli/main.py", line 130, in cli_run
    ret = resolving(cli, base)
  File "/usr/lib/python3.11/site-packages/dnf/cli/main.py", line 183, in resolving
    base.do_transaction(display=displays)
  File "/usr/lib/python3.11/site-packages/dnf/cli/cli.py", line 248, in do_transaction
    self.gpgsigcheck(install_pkgs)
  File "/usr/lib/python3.11/site-packages/dnf/cli/cli.py", line 304, in gpgsigcheck
    self._get_key_for_package(po, fn)
  File "/usr/lib/python3.11/site-packages/dnf/base.py", line 2552, in _get_key_for_package
    keys = dnf.crypto.retrieve(keyurl, repo)
  File "/usr/lib/python3.11/site-packages/dnf/crypto.py", line 137, in retrieve
    keyinfos = rawkey2infos(handle)
  File "/usr/lib/python3.11/site-packages/dnf/crypto.py", line 127, in rawkey2infos
    keys = libdnf.repo.Key.keysFromFd(key_fo.fileno())
  File "/usr/lib64/python3.11/site-packages/libdnf/repo.py", line 341, in keysFromFd
    return _repo.Key_keysFromFd(fileDescriptor)
RuntimeError: Error during parsing OpenPGP packets
This issue was reported against dnf unrelated to OpenMandriva:
The stacktrace is identical. There’s a link to a merged PR at the bottom that apparently fixes the problem. If that commit could be pulled in, that would likely fix the issue with us installing google-chrome from google’s repo.
