2disbetter
(Rocking Rock 6.0 on a Framework 13 (12th Gen Intel))
1
Latest Rock
KDE
Portmaster will install and appear to work, but when starting the backend (core) it is unable to start iptables.
Relevant information (hardware involved, software version, logs or output…):
Portmaster is an open source firewall application that allows you to control which applications are allowed to talk to the internet, etc.
And please put a link to your bug report here. The error message is telling what is wrong. I do know that the package iptables is not installed by default, So try installing that first. You can run this to see if it is or is not installed.
rpm -qa | grep iptables
I am pretty sure portmaster is not OpenMandriva software.
Edit: So maybe I was wrong initially about the bug report idea, I initially thought this was OM software. Users need to be more specific about this, it matters.
2disbetter
4
Well what do you know. That fixed it. Would help if I installed it. I just assumed the package pulled it in by itself or that it was installed by default.
