Pi-hole on OM?
Just a real quick question. Has anyone gotten Pi-hole running well on OM without having to resort to a VM?
I might try it on one of my server machines.
I suggest do it on a server. I use Adguard Home to do ad block and content blocking. It is installed as a docker on my Unraid server and protects my entire network at the DNS level. Works pretty good. Adblock is not total but the adult content blocking seems to work very well. I also have social media sites blocked.
Pi-hole works similarly well.
Docker-ize and everything should be working fine (at least for me on: jellyfin, audiobookshelf, and freshrss)
Thanks for the suggestion. I’m sure that is the best way to go about it.
But as I noted in my OP I very much would rather not have to go that route.
I am probably just going to stick with ublock origin on all my browsers and let the 2 Roku’s I have, continue to serve up adds. (And no none of the methods of turning off adds on a Roku, work any more)
