Note to self: I need Hugo static website generator.
Needs work:
Oh, wait ![]()
You mean the CMS.
It’s currently being worked on. I’m currently able to build a rpm package and install it. However, I need to find out how we handle Go dependencies within the reposistories.
I believe you use the updater on the source manually then compress to a file containing the whole thing. Similar to:
