Package mlocate installed yet, command mlocate not found - and more
**OpenMandriva Lx version:6
**Desktop environment (KDE, LXQT…):*irrelevant *
Package mlocate installed yet command mlocate not found
LC_ALL=C sudo dnf install mlocate
[sudo] password for kuba:
Last metadata expiration check: 4:49:37 ago on Wed Apr 23 10:11:51 2025.
Dependencies resolved.
 Package          Architecture    Version            Repository            Size
Installing:
 mlocate          x86_64          0.26-26            rock-x86_64          100 k
Transaction Summary
Install  1 Package
Total download size: 100 k
Installed size: 339 k
Is this ok [y/N]: y
Downloading Packages:
mlocate-0.26-26-omv4050.x86_64.rpm              168 kB/s | 100 kB     00:00
Total                                           167 kB/s | 100 kB     00:00
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Preparing        :                                                        1/1
  Running scriptlet: mlocate-0.26-26.x86_64                                 1/1
  Installing       : mlocate-0.26-26.x86_64                                 1/1
Created symlink '/etc/systemd/system/timers.target.wants/updatedb.timer' -> '/usr/lib/systemd/system/updatedb.timer'.
Warning: The unit file, source configuration file or drop-ins of updatedb.timer changed on disk. Run 'systemctl daemon-reload' to reload units.
Installed:
Complete!
kuba@kuba:~$ LC_ALL=C sudo systemctl daemon-reload
Let’s try to use command
sudo updatedb
LC_ALL=C mlocate -b *cov
bash: mlocate: nie znaleziono polecenia <-- btw this should be translated to English.
It should be bash: mlocate: command not found
same goes with sudo  mlocate -b *cov
now
whereis mlocate
mlocate:       ?????
So maby
kuba@kuba:~$ sudo whereis mlocate
mlocate:            ?????!!!??? nope
kuba@kuba:~$
Oh, ok, package is installed, but it is in a fact not installed.
Lets check that
kuba@kuba:~$ LC_ALL=C sudo dnf install mlocate
Last metadata expiration check: 5:13:41 ago on Wed Apr 23 10:11:51 2025.
Package mlocate-0.26-26.x86_64 is already installed.
Nothing to do.
Complete!
kuba@kuba:
so i tried as last resort
sudo /usr/bin/mlocate -b *W-8 BEN*
[sudo] hasło użytkownika kuba:
sudo: /usr/bin/mlocate: nie znaleziono polecenia
Nope
Now, either I’m a moron or my installation is broken.
I used this particular iso as mu installation source OpenMandrivaLx.6.0-snapshot.20250420.3876-plasma6x11.x86_64.iso
I had a weird issues with it from the very beginning
First om-welcome glich then super -p does not work on kde
Plasma 6.3.5 patch
Bero said
berocooker
We already have that patch
Those were issues I have reported in form of questions but I had more
I’m extremely confused at this point.
Option 1 I’m an idiot and all of this happened by my lack of skill and wrong doing. And that is quite probable cause
Option 2 OM was released a bit too early, and we have some errors that go unnoticed under the radar. Yup maby
Option 3 Black hole physics or black magic are all to blame
What if you manually mark the package as installed? Guessing here.
sudo dnf mark install mlocate
is there any plocate or llocate possible ?
mlocate -b cov*
bash: mlocate: nie znaleziono polecenia <-- mlocate command not found
kuba@kuba:~$
plocate works
plocate -b cov.*
/home/kuba/Pulpit/z-pulpitu/cov.mp4
mlocate didn’t work on OM5 also and I forgot about that
Maybe it should be removed from the repos ?
Now i have strange issue with pulseaudio and sound in shotcut
I must read logs first, but not today.
I’m bugging you all with my strange issues for 3 days straight.
To be fair, I feel a little ashamed / bad with it.
I really should deep dive in logs before any next question
It may be pulseaudio issue, shotcut issue, OM6 issue or im an idiot issue
As I said before
:stuck_out_tongue: :wink:
Very easy solution: you can use the binary locate for both mlocate or plocate. You may check it looking at the package content
dnf repoquery --list mlocate
dnf repoquery --list plocate
mlocate plocate is “frontend” of locate I had no idea about, that thank-you.
Isn’t this solved. If so please mark this as solved.
mlocate is very old coming from gnome Gtk2 and use also by Mate
this have review after with plocate to optimize db
I think there’s 2 different things called mlocate, which may well be causing the confusion.
We have THIS mlocate: Overview - mlocate - Pagure.io - it’s in the mlocate package, it’s an implementation of the “locate”/“updatedb” tools and is CLI only. The binary is just called “locate” because that’s what the standards expect us to have – so install mlocate and invoke it as “locate”.
And then there’s some obscure locate frontend (probably originating from Mate) that makes use of the locate tool. We don’t currently package this.
FWIW it is probably recommendable to use plocate over mlocate. That, too, is an implementation of the locate command, and it, too, is called locate in the filesystem because that’s where it’s expected.
Some other distros rename mlocate to mlocate and plocate to plocate, but IMO that doesn’t make much sense – it’s a system wide tool (and updatedb needs to run globally), so there’s no reason why someone would want to install multiple locate implementations at the same time.
true
@ben79 I would happily mark this as solved… but i have no freaking idea how. (I’m incapable to edit a title of original post)
Under each post, there is a box with a check mark in it. Pick the post that solved your issue and click that box.
oh shit :rofl: sorry
done
