The partitioning module of Calamares 2.4.5 requires KPMcore 2.2 or 2.2.1. Further distribution-specific deployment adjustments may be needed for full LUKS support, for more details seethe Calamares wiki.
Under OpenMandrivaLx2014 I used the set-up where a small boot partition was not encrypted but the other partitions, /, home, swap, … were LUKS encrypted and the boot loader was placed on the /dev/sdc disk.
Is this set-up still possible with calamares and can you give me some pointers how it is done on OpenMandrivaLx3.0
Technically recent version of GRUB2 supports LUKS so a separate /boot partition is not mandatory, however many distro installer don’t support this yet so if you choice such a configuration you should install GRUB with the right options by hand in a second time (for instalce from a live system).
If your trying to install Lx 3.0 then the cooker packages are irrelevant. Here are the package versions on the official Lx 3.0 x86_64 (build ID 507) installer/iso.
First my understanding of the problem is that LUKS encryption is working and the issue is that installer installs grub2 on /dev/sda instead of /dev/sdc?
If so it’s either a bug in installation script or grub2 script. Any way a bug report is in order here.
No, look under attachments, there is no bug report log attached. How could I attach your bug report log anyway? It needs to come from your computer and either the install .iso or operating system on your computer.
Sorry, I was a little bit confused. I thought that you wanted me to insert the link of this discussion into the 1998 bug report (see comment 2).
Now I realize that you want me to run the “omv-bug-report” script on my new installation. The problem is that there is not yet a new openMandrivaLx3.0 installation. Do you want me to run the “omv-bug-report” script on my active live openMandrivaLx3.0 USB stick?
