OpenMandriva ROME 24.07 Release Candidate
We are excited to announce the unscheduled Release Candidate for OpenMandriva rolling release model, ROME 24.07. This release brings significant updates and improvements.
This is a companion discussion topic for the original entry at https://www.openmandriva.org/en/news/article/openmandriva-rome-24-07-release-candidate
Hi, there is no plasma6.wayland.znver1 iso?
Celebrate Independence Day this Fourth of July by switching to Linux
(Cooker chefs suggest: OpenMandriva ROME 24.07 :stuck_out_tongue_closed_eyes: )
Courtesy of betanews.com
OpenMandriva ROME 24.07 Release Candidate is here: Download the Linux distribution now
Thanks
OpenMandriva has released a new candidate version for its rolling release model, ROME 24.07. This update brings Plasma 6 as the default desktop environment, incorporating various new features and improvements.
OpenMandriva 24.07 RC “ROME”发布
Courtesy of linuxeden.com
Thanks
OpenMandriva 项目宣布推出新的测试快照。 OpenMandriva 24.07 “ROME “的新候选发布版引入了 KDE Plasma 6 桌面环境。 “最显著的变化之一是将 Plasma 6 改为默认桌面环境。 这个重要的 KDE Plasma 桌面版本提供了一系列新功能和增强功能。 我们的发布工程师努力工作,以确保 Plasma 5 和 Plasma 6 软件包在必要时可以共存。 虽然我们相信 Plasma 6 已可用于日常使用,但我们也为喜欢 Plasma 5 的用户提供了最新的 ISO 映像,其中包含最新的稳定 Plasma 5 桌面。 ROME 24.07 和即将发布的 OMLx Rock 5.1(固定点版本)将是提供 Plasma 5 桌面的最后几套安装镜像。 这些版本包括 Plasma 5 的最新和预期最终版本,是希望继续长期使用 5.x 系列的用户的理想选择。 GNOME 46.2 桌面和 LXQt 2.0.0 也已发布。
Just cooked, upon request :wink:
ROME Plasma6 wayland znver1 iso
(not tested, looking forward to read your feedback)
OpenMandriva ROME 24.07 RC
Courtesy of hup.hu
Thanks
Tesztelhető az OpenMandriva 24.07 kiadásra jelölt verziója. Benne jelentős változások.
OpenMandriva ROME 24.07 RC terá KDE Plasma 6 e pacotes Proton
Courtesy of sempreupdate.com.br
Thanks
A distribuição OpenMandriva ROME 24.07 RC terá KDE Plasma 6 e pacotes Proton. Portanto, o OpenMandriva ROME 24.07 RC está disponível para testes durante o fim de semana de feriado dos EUA ou apenas no verão.
Um release candidate da distribuição de lançamento contínuo OpenMandriva ROME 24.07 já está disponível. Notavelmente, com esta atualização do OpenMandriva ROME está mudando para o desktop KDE Plasma 6 por padrão, mas continuando a manter os pacotes do Plasma 5 por perto para aqueles desconfortáveis com o desktop atualizado. O GNOME 46.2 e o LXQt 2.0 também estão disponíveis como opções alternativas de desktop para aqueles que não querem seguir a rota do KDE Plasma.
A OpenMandriva também está empacotando pacotes de “prótons” e “prótons-experimentais” para aqueles sabores downstream do Wine que alimentam o Steam Play da Valve. OpenMandriva está empacotando essas construções Proton para aqueles que querem fazer uso de Proton e Proton Experimental fora dos limites do Steam ou construir a partir do código fonte você mesmo.
OpenMandriva ROME 24.07 RC também possui o kernel Linux 6.9.7 por padrão, o LLVM Clang 18.1 toolchain, systemd 255.7, LibreOffice 24.2.4, Firefox 127, e uma riqueza de outras atualizações de pacotes.
OpenMandriva ROME 24.07 RC nasazuje KDE Plasma 6 a Proton
Courtesy of root.cz
Thanks
Kandidát na budoucí vydání OpenMandrivy ROME 24.07 se konečně „posouvá do budoucnosti“, když nasazuje jako výchozí desktopové prostředí nejnovější řadu KDE Plasma 6.1.1 + KDE Applications 24.05.1 + KDE Frameworks 6.3.0. Vedle toho uživatelé mohou též volit novější verze jiných jako GNOME 46.2 či LXQt 2.0.
Jak by pravil Horst, to není vše. OpenMandriva kromě toho zachovává i podporu Plasmy 5 a přidává také mezi balíčky i Proton, resp. Proton-Experimental, tedy Wine implementaci známou z Valve Steam, zde pro obecné užití. K tomu přidejme jádro Linux 6.9.7, novější kompilační balík LLVM/Clang 18.1, systemd 255.7, LibreOffice 24.2.4 (s integrací Qt6/Plasma 6), Firefox 127, Chromium 126.0.6478.126, Falkon 24.05.1, Virtualbox 7.0.18, Krita 5.2.3, Gimp 2.10.38, Digikam 8.3.0, OBS Studio 30.2.0 beta, QMPlay2 24.06.16, VLC 3.0.21, Telegram Desktop 5.1.7 atd.
Disponibile OpenMandriva ROME 24.07 Release Candidate
(Italiano)
Siamo lieti di annunciare la Release Candidate (fuori programma) per l’edizione rolling di OpenMandriva, ROME 24.07.
Questa release apporta aggiornamenti e miglioramenti significativi.
Uno dei cambiamenti più importanti è il passaggio a Plasma 6 come ambiente desktop predefinito.
I nostri sviluppatori si sono assicurati che i pacchetti Plasma 5 e Plasma 6 possano coesistere, ove necessario.
Benchè riteniamo che Plasma 6 sia pronto per l’uso quotidiano, forniamo anche un’immagine ISO aggiornata con Plasma 5.
ROME 24.07 e l’imminente Rock OMLx 5.1 saranno gli ultimi set di immagini di installazione che offriranno il desktop Plasma 5. Queste immagini includono le ultime versioni finali di Plasma 5 per gli utenti che desiderano continuare a usare la serie 5.x per più tempo.
Anche se i test interni indicano una transizione senza problemi consigliamo vivamente di effettuare una nuova installazione se si sceglie Plasma 6, per godere appieno delle ultime funzionalità dell’ambiente desktop.
Quanto prima, Cooker inizierà gradualmente a eliminare Plasma 5.
Nel momento in cui questa modifica sarà completata e integrata nel ramo di sviluppo, gli utenti di ROME con Plasma 5 passeranno automaticamente a Plasma 6. Gli utenti di Rock passeranno a Plasma 6 solo se sceglieranno Rock 6.0 o superiore.
Oltre al desktop predefinito KDE Plasma, offriamo anche spin con LXQt 2.0.0 e GNOME 46.2.
Lo spin LXQt offre l’ambiente LXQt 2.0, la prima versione di questo desktop leggero a passare a Qt 6.
Un’altra importante novità sarà gradita a chi vuole ancora utilizzare applicazioni realizzate per Windows, e in particolare i giochi: Proton e Proton-experimental, varianti di wine tipicamente utilizzate per eseguire giochi Windows all’interno di Steam, sono ora disponibili nei repository dei pacchetti OpenMandriva oltre al normale emulatore Wine.
Per la prima volta, ciò rende Proton utilizzabile al di fuori di Steam, senza la necessità di installare alcun codice non free.
OM-Welcome è stato rinnovato, accorpando i moduli già presenti nelle due storiche applicazioni a marchio OpenMandriva oma-welcome e om-control-center.
Lo scopo di questa modifica è quello di essere un comodo punto di partenza centralizzato all-in-one sia per la configurazione del sistema che per l’installazione del software.
Per quanto riguarda i punti salienti e i principali cambiamenti vi rimando al relativo capitolo nella news originale.
OpenMandriva 24.07 ROME Release Candidate con Plasma 6.1
(Español - Spanish)
by Máquinas Linuxeras
Muchas gracias por el vídeo
