In the last update they made a point of how many AI tools are packaged for OpenMandriva. I use Gemini and ChatGPT for various things, mostly problem solving. I had a long string in Gemini about baking bread in my new bread machine. Today I tried to open the thread and it failed the point that it had trouble loading and when it did it wouldn’t let me copy it. I remembered I had Hermes on my computer from about a month ago when I first played with it.
Now I did have to change some settings from not having it going for a month but about 5 minutes of trouble shooting and I had it working again. I asked Hermes about taking over bread making responsibilities and how to catch all the context from the Gemini thread. I actually had to reboot my computer to be able to copy the thread manually.
So Hermes was able to catch all that context and we made an agent that only deals with bread making duties.
Now here is the crazy part, Hermes is Way more accurate than Gemini. I had to correct Gemini on something on almost every step of the process when helping create a recipe. Hermes hasnt made an obvious mistake yet.
If you are already using browser based AI maybe give a local model a try. Its not hard to set up.
A well timed post. I was thinking of giving a local model a try, but I honestly didn’t know where to start much less which one to try. Thanks for the suggestion.
Ya and its a lot easier to get it up and running than you would think. If you watch a how-to on youtube it is a lot more involved than installing it on OpenMandriva. Really all one needs to do to get going is open Konsole and enter
sudo dnf in hermes-agent.noarch
Once it is installed and running just ask it what it needs from you to operate fully and efficiently and it will tell you what to do. It will actually want to do it for you but I have it teach me how to do it myself.
OpenMandriva also has a lot of tools and models already natively available in our repositories. From the update notes last month we have
Note: I am not an experienced Linux user. I am a novice.
I was eventually able to get Lx 6.0 (Vanadium) Rock to run on an older MB, ASUS M5A78L because of ChatGPT. After hours and hours it eventually found the “bug” and a gave me a “fix”. ChatGPT then made a detailed report.
I do not know if this is either where or how to share the results. I would like to offer this ChatGPT document if anyone is interested. I hope this is helpful.
Yes, just make a thread detailing the problems and the solution. Heck you personally might need it later. Lord knows Ive went back to my own write ups on here so I didnt have to relearn something.
Unfortunately I cannot understand how to fill in the “new topic” page when I try to make one for my ChatGPT document. I guess it may be something about HTML in light grey fill-ins. I am not an HTML programmer. Ideas? Thank you!
