Openmandriva LX 4 dnf upgrade error package cpupower-5.2.-0.rc1.1
Hi get:
cpupower-5.2.-0.rc1.1-omv4000.x86_64.rpm: Downloading successful, but checksum doesn't match. Calculated: 5cfa3cdccc2d9207876e3afb69034d6e12659460aa1ab6a2f73ad395b3c0c279(sha256)  Expected: 0c1631bac229515ce54a5f18c82eda1b4cdcd77479ebda8aff273b82c110cf49(sha256)
[FAILED] cpupower-5.2.-0.rc1.1-omv4000.x86_64.rpm: No more mirrors to try - All mirrors were already tried without success
(23-24/438): lib64python-devel-3.7.3-4-o  0% [                                        ] 678 kB/s | 2.9 MB     12:53 ETA
You can remove cached packages by executing 'dnf clean packages'.
Error: Error downloading packages:
  Cannot download cpupower-5.2.-0.rc1.1-omv4000.x86_64.rpm: All mirrors were tried
try to use sudo dnf upgrade --excludepkgs=cpupower-5.2.-0.rc1.1-omv4000.x86_64.rpm but get still this error.
I copied and pasted your command and it works here.
You encountered a temporary problem with ABF which seems fixed now.
Yes sometimes it happens. Not very often but sometimes it does.
Just need to clean cache and run the command again.
I have tryed to do that, but its give error with kernel, did VPN and Virtualbox may give some issue with that? Not sure its use VPN settings or not. But its look like Vmware\virtualbox give more issue with it than other computer.
dnf update -x kernel-* how did you include cpupower than take install of it later?
some issue with dnf upgrade? Did not help with dnf clean because i get the samme issue again, need to use sudo dnf upgrade --nogpgcheck
Running transaction check
Transaction check succeeded.
Running transaction test
Feil: Transaction check error:
  file /usr/lib64/libKF5CalendarCore.so.5 from install of lib64KF5CalendarCore5-19.04.2-1.x86_64 conflicts with file from package lib64KF5CalendarCore5-19.04.1-1.x86_64
Error Summary
