Upgrading:
lib64mutter-gir4.0 x86_64 3.32.2-1 cooker-x86_64 1.1 M
lib64mutter0 x86_64 3.32.2-1 cooker-x86_64 457 k
mutter x86_64 3.32.2-1 cooker-x86_64 526 k
opera-stable x86_64 60.0.3255.170-0 opera 60 M
Reinstalling:
enchant x86_64 1.6.1-5 cooker-x86_64 49 k
fonts-ttf-decoratives noarch 1.3-39 cooker-x86_64 435 k
fonts-ttf-west_european noarch 1.3-39 cooker-x86_64 138 k
ipcalc x86_64 0.2.5-1 cooker-x86_64 24 k
kimap x86_64 19.04.2-1 cooker-x86_64 37 k
lib64KF5CalendarCore5 x86_64 19.04.2-1 cooker-x86_64 194 k
replacing lib64KF5CalendarCore5.x86_64 19.04.2-1
lib64KF5IMAP5 x86_64 19.04.2-1 cooker-x86_64 133 k
lib64KF5Mbox5 x86_64 19.04.2-1 cooker-x86_64 24 k
lib64apr-util1_0 x86_64 1.6.1-3 cooker-x86_64 71 k
lib64enchant1 x86_64 1.6.1-5 cooker-x86_64 21 k
lib64nspr4 x86_64 4.21-1 cooker-x86_64 124 k
lib64revenge0.0_0 x86_64 0.0.4-3 cooker-x86_64 49 k
lib64vorbis0 x86_64 1.3.6-4 cooker-x86_64 79 k
lib64vorbisenc2 x86_64 1.3.6-4 cooker-x86_64 74 k
lib64vorbisfile3 x86_64 1.3.6-4 cooker-x86_64 19 k
x11-server-common x86_64 1.20.5-1 cooker-x86_64 445 k
x11-server-xorg x86_64 1.20.5-1 cooker-x86_64 1.0 M
x11-server-xwayland x86_64 1.20.5-1 cooker-x86_64 933 k
Transaksjonsammendrag
Upgrade 4 Packages
Totale størrelse på pakker som hentes: 66 M
Er dette ok [j/N]: j
Laster ned pakker:
(1/22): enchant-1.6.1-5-omv4000.x86_64.rpm 337 kB/s | 49 kB 00:00
(2/22): ipcalc-0.2.5-1-omv4000.x86_64.rpm 367 kB/s | 24 kB 00:00
(3/22): kimap-19.04.2-1-omv4000.x86_64.rpm 539 kB/s | 37 kB 00:00
(4/22): fonts-ttf-west_european-1.3-39-omv4000.noarch.rpm 475 kB/s | 138 kB 00:00
(5/22): lib64KF5IMAP5-19.04.2-1-omv4000.x86_64.rpm 888 kB/s | 133 kB 00:00
(6/22): fonts-ttf-decoratives-1.3-39-omv4000.noarch.rpm 971 kB/s | 435 kB 00:00
(7/22): lib64KF5CalendarCore5-19.04.2-1-omv4000.x86_64.rpm 903 kB/s | 194 kB 00:00
(8/22): lib64KF5Mbox5-19.04.2-1-omv4000.x86_64.rpm 340 kB/s | 24 kB 00:00
(9/22): lib64apr-util1_0-1.6.1-3-omv4000.x86_64.rpm 882 kB/s | 71 kB 00:00
(10/22): lib64enchant1-1.6.1-5-omv4000.x86_64.rpm 334 kB/s | 21 kB 00:00
(11/22): lib64revenge0.0_0-0.0.4-3-omv4000.x86_64.rpm 957 kB/s | 49 kB 00:00
(12/22): lib64vorbis0-1.3.6-4-omv4000.x86_64.rpm 962 kB/s | 79 kB 00:00
(13/22): lib64vorbisenc2-1.3.6-4-omv4000.x86_64.rpm 905 kB/s | 74 kB 00:00
(14/22): lib64nspr4-4.21-1-omv4000.x86_64.rpm 805 kB/s | 124 kB 00:00
(15/22): lib64vorbisfile3-1.3.6-4-omv4000.x86_64.rpm 293 kB/s | 19 kB 00:00
(16/22): x11-server-common-1.20.5-1-omv4000.x86_64.rpm 2.0 MB/s | 445 kB 00:00
(17/22): x11-server-xorg-1.20.5-1-omv4000.x86_64.rpm 2.1 MB/s | 1.0 MB 00:00
(18/22): x11-server-xwayland-1.20.5-1-omv4000.x86_64.rpm 2.0 MB/s | 933 kB 00:00
(19/22): lib64mutter-gir4.0-3.32.2-1-omv4000.x86_64.rpm 3.1 MB/s | 1.1 MB 00:00
(20/22): lib64mutter0-3.32.2-1-omv4000.x86_64.rpm 2.8 MB/s | 457 kB 00:00
(21/22): mutter-3.32.2-1-omv4000.x86_64.rpm 2.5 MB/s | 526 kB 00:00
(22/22): opera_stable-60.0.3255.170-linux-release-x64-signed.rpm 8.7 MB/s | 60 MB 00:06
Totalt 8.0 MB/s | 66 MB 00:08
Running transaction check
Transaction check succeeded.
Running transaction test
You can remove cached packages by executing 'dnf clean packages'.
error: Transaction check error:
file /usr/lib64/libKF5CalendarCore.so.5 from install of lib64KF5CalendarCore5-19.04.2-1.x86_64 conflicts with file from package lib64KF5CalendarCore5-19.04.1-1.x86_64
Error Summary
That is Cooker not 4.0. They are different now and they are different repositories.
Post-edit: Otherwise if you don’t have time to describe your problem why would anyone have time to help.
But i try to charge to release x86-64 bits with update and nonfree.
But its take a lot of time, maybe did not works?
I think maybe i need to reinstall everything.
Can i get some expert to help me litle? Because completly reinstall try i to avoid because a lot of time it will take.
