OpenMandriva Lx 3.02 development continues
Just now I checked errors are generatiing in “Hugin Calibrate Lens” and “Virtual Machine Manager”. VMM crash
ASSERT INFO:
./src/gtk/bitmap.cpp(1262): assert “bmpData->m_pixbufNoMask” failed in SetSourceSurface(): no bitmap data
BACKTRACE:
[1] wxBitmap::SetSourceSurface(_cairo*, int, int, wxColour const*, wxColour const*) const
[2] wxBitmap::Draw(_cairo*, int, int, bool, wxColour const*, wxColour const*) const
[3] LensCalImageCtrl::OnPaint(wxPaintEvent&)
[4] wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&)
[5] wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*)
[6] wxEvtHandler::TryHereOnly(wxEvent&)
[7] wxEvtHandler::ProcessEventLocally(wxEvent&)
[8] wxEvtHandler::ProcessEvent(wxEvent&)
[9] wxEvtHandler::SafelyProcessEvent(wxEvent&)
[10] wxWindow::GTKSendPaintEvents(_cairo*)
[11] _gtk_marshal_BOOLEAN__BOXED
[12] g_closure_invoke
[13] g_signal_emit_valist
[14] g_signal_emit
[15] gtk_widget_draw_internal
[16] gtk_container_propagate_draw
[17] gtk_widget_draw_internal
[18] gtk_container_propagate_draw
[19] gtk_css_gadget_draw
[20] gtk_widget_draw_internal
[21] gtk_container_propagate_draw
[22] _gtk_marshal_BOOLEAN__BOXED
[23] g_closure_invoke
[24] g_signal_emit_valist
[25] g_signal_emit
[26] gtk_widget_draw_internal
[27] gtk_container_propagate_draw
[28] _gtk_marshal_BOOLEAN__BOXED
[29] g_closure_invoke
[30] g_signal_emit_valist
[31] g_signal_emit
[32] gtk_widget_draw_internal
[33] gtk_container_propagate_draw
[34] gtk_css_gadget_draw
[35] gtk_widget_draw_internal
[36] gtk_container_propagate_draw
[37] gtk_widget_draw_internal
[38] gtk_widget_render
[39] gtk_main_do_event
[40] _gdk_event_emit
[41] g_closure_invoke
[42] g_signal_emit_valist
[43] g_signal_emit
[44] g_main_context_dispatch
[45] g_main_loop_run
[46] gtk_main
[47] wxGUIEventLoop::DoRun()
[48] wxEventLoopBase::Run()
[49] wxAppConsoleBase::MainLoop()
[50] wxEntry(int&, wchar_t**)
[51] main
[52] __libc_start_main
[53] _start
gnutu, tuxmath, childsplay, matchbox-keyboard - Crash. I told Education section has problems. more there.
I like the Grub image with the progress bar. Previously OM Lx had it.
Tired to install VMware Workstation 12.5 Player for Linux 64-bit. installed. but VMware Player crash.
[root@Pujitha-PC Downloads]# chmod 777 VMware-Player-12.5.5-5234757.x86_64.bin
[root@Pujitha-PC Downloads]# ./VMware-Player-12.5.5-5234757.x86_64.bin
Extracting VMware Installer…done.
/usr/share/themes/Breeze/gtk-2.0/widgets/entry:70: error: unexpected identifier direction', expected character }’
/usr/share/themes/Breeze/gtk-2.0/widgets/styles:36: error: invalid string constant “combobox_entry”, expected valid string constant
How about TeamViewer any one checked?
Cannot execute dolphin as root.
Development build ISO 993, repo /testing enabled. Updated KApps 17.04.0.
[ruru@omlx-993 ~]$ kdesu dolphin
QXcbConnection: XCB error: 3 (BadWindow), sequence: 784, resource id: 31457801, major code: 40 (TranslateCoords), minor code: 0
[ruru@omlx-993 ~]$ su -
Password:
[root@omlx-993 ~]# dolphin
Executing Dolphin as root is not possible.
Password:
[root@omlx-993 ruru]# dolphin
[ruru@omlx-993 ~]$ rpm -qa|grep dolphin
lib64dolphinvcs5-17.04.0-1-omv2015.0.x86_64
lib64dolphinprivate5-17.04.0-1-omv2015.0.x86_64
dolphin-17.04.0-1-omv2015.0.x86_64
dolphin-plugins-17.04.0-1-omv2015.0.x86_64
Anyone else tried?
I haven’t investigated at kde.org yet. Same thing happened in openSUSE when updated to KApps 17.04 so this is probably an upstream feature “for our own good”… You’ll probably find you can’t use a lot of KDE apps like kwrite, kate, ect. as well.
I think it’s a security feature. You may try with
sudo dolphin
I’m sure that’s what the persons who made the decision think. Some of us got in to Linux because it gave us the choice of how to manage our own systems. In that vein I’m sure there are ways to circumvent but as a QA person I’m going to live with it and work around it. Think about it though. For anyone with the knowledge to do things as root/su exactly what will we not continue doing as root/su with different tools. Nothing, not a damn thing. So it eludes me what has actually been fixed. I have seen zero problems in this, KDE, Fedora, or openSUSE forums caused by someone using Dolphin as root. Not saying it hasn’t happened but it certainly is not a common problem.
Aside: ben79 rummaging around asking “where did I put those anti-rant pills”…
To be specific:
$ sudo dolphin
[sudo] password for ben79:
IMO something not broken is now fixed. Congratulations!
pujithadimuthu thanks for reporting. What got devede and bleachbit fixed was mandian filing bug reports. So to get these other issues fixed I, you, or someone needs to file some bug reports. I’d suggest doing 2 or 3 and then when those are fixed or are otherwise RESOLVED file another 2 or 3. That’s just respecting our limited resources and our developers time. A few of these may need to be removed instead of fixed but that is a resolution where warranted. (For instance packages that are no longer maintained).
That being said it is important that you have reported this and that we eventually get these applications either fixed or in a few cases removed. Obviously the more people that pitch in and help the sooner accomplished.
pujithadimuthu again thanks for reporting and ditto the above post.
I hope it is a bug.
When I’m root I am root and can do whatsoever I want.
If it’s not a bug, well… stop believing users are stupid.
Also, if they are they surely will find tons of ways to destroy their
systems.
I hoped in vain :angry:
kde.org 17.04.0 changelog
Disallow executing Dolphin as root on Linux
+1
Postedit
Actually OffTopic, I would really need a workaround for this problem as I have to edit files and make changes while locally testing some stuff so…
I know I can run as root pcman-fm for example but dolphin is dolphin and I’m used to use it only.
Any help, please?
Have you already tried with pkexec dolphin?
You can patch the code, of course. ;).
To be more seriously I see people on other forum complaint against this. Maybe KDE developers will change it in the future.
However there is nothing you can do in dolphin you can’t do in terminal.
VMM is working.. Has any one checked Hypervisors… KVM is not available. My guess. I think quem and libvirt is available. I did not check. I am busy…
As I know KVM supports Linux and Windows OS and lot of people use KVM.
No. Will try soon and report. TY.
XEN hypervisor is available in openmandriva-drakconf (MCC) install or remove programs but does not work. openmandriva-drakconf (MCC) services can not start / start services manually. This Service issue had in omlx 3.0 tooo.
Up to now:
VirtualBox is OK
Virtual Machine Manager is OK.
But Virtual Machine Manager hypervisors has problems.
KVM - Not available
XEN - Installed Not working
qemu - Not checked
libvirt - not working
VMware Player not working
Couple of months ago I had this issue with network connection. My ADSL has to restart after login to connect to internet.
last two weeks I did not got that problem now again started. I told this to Mr. Efrem couple of moths ago. He told he will give a try.
[ruru@omlx-993 ~]$ pkexec dolphin
Password:
[root@omlx-993 ruru]# pkexec dolphin
After installing the latest update Grub shows XEN option in the boot menu. XEN HV 4.5.1 but OM Lx does not boot.
pkexec dolphin does not open.
[dimuthu@Pujitha-PC ~]$ su - root
Password:
[root@Pujitha-PC ~]# pkexec dolphin
pkexec: Relink /lib64/libmount.so.1' with /lib64/librt.so.1’ for IFUNC symbol `clock_gettime’
QXcbConnection: Could not connect to display
Aborted (core dumped)
[root@Pujitha-PC ~]# dolphin
will open dolphin with out icon images
FWIW I read that openSUSE patched the package now :stuck_out_tongue_closed_eyes:
I learn that this “feature” has been introduced for security reasons.
I tried to install adobe reader. Most people use it. As I know adobe stooped the Linux adobe reader.
Is there any alternative software for Adobe reader. Which has the same functionality? PDFedit and Okular is available for free. But it is not the same as adobe reader. Master PDF Editor and Qoppa PDF Studio 11 is available for linux. but not free.
I got AdbeRdr9.5.5-1_i486linux_enu.rpm. When I tried to install it.
[root@Pujitha-PC Downloads]# urpmi AdbeRdr9.5.5-1_i486linux_enu.rpm
(medium “Main32”)
libpangox1.0_0 0.0.2 9 omv 2015.0 i586
(medium “Main32 (Einsteinium3.0-3)”)
libxft2 2.3.2 9 omv 2015.0 i586
libxt6 1.1.5 4 omv 2015.0 i586
(medium “Main32 Updates (Einsteinium3.0-4)”)
libgdk_pixbuf_xlib2.0_0 2.36.3 1 omv 2015.0 i586
libpangoxft1.0_0 1.40.3 1 omv 2015.0 i586
(command line)
AdobeReader_enu 9.5.5 1 i486
135MB of additional disk space will be used.
57MB of packages will be retrieved.
Proceed with the installation of the 6 packages? (Y/n) y
[root@Pujitha-PC Downloads]# urpmi master-pdf-editor-4.1.30_qt5.x86_64.rpm
SECURITY: The following package is NOT signed (OK ((none))): master-pdf-editor-4.1.30_qt5.x86_64.rpm
installing master-pdf-editor-4.1.30_qt5.x86_64.rpm
Preparing… ############################################################################################################################################
1/1: master-pdf-editor ############################################################################################################################################
Unknown media type in type ‘all/all’
Unknown media type in type ‘all/allfiles’
/usr/bin/gtk-update-icon-cache: Relink /lib64/libmount.so.1' with /lib64/librt.so.1’ for IFUNC symbol `clock_gettime’
Last year I have seen a comment somewhere telling that Adobe Acrobat DC works with POL (Play on Linux). Maybe worth giving a try?
