I’m not here to talk down to anybody or something.
I’m just stating the fact, Open mandriva 6 with rtx 3060 is a big no go.
I have issues with my main OM setup, so I decided to install it on a secondary disk to see if clean install will help. I would have try to resolve some minor issues in a process (if I could start an installer of any sort). Maybe It would help me and someone else with a similar set of issues.
I can boot iso and that’s about it. I can see boot screen with the nice flowers and setup options, so some very, very basic video rendering works. But after that point, no matter which option I choose I end up with black screen. The only indication that my monitors works is a blue blight on the monitor frame, which turns yellow if a monitor goes into a sleep mode.
One and only thing that can be start and works is a cli mode - clean console.
At that point I probably should read how to set up open mandriva server in a cli mode in hope that same way of installation is available on regular desktop version of a distro
Im not here to talk shit or anything. I merely state a simple fact, open mandriva cannot be install on nvidias that aren’t ancient.
I have a really old nvidia laptop where the installation is as follows: not straight forward but also not very difficult. But most importantly it is possible and after installation it works crazy good.
If you have RTX 3060 installation is impossible. If you installed OM6 using different gpu (radeon), yes you can manage to install nvidia drivers yet working with (not ancient) nvidia is to said it mildly difficult and not stable experience.
The NVIDIA GeForce RTX 3060 12GB was released on February 25, 2021 so it is not so new but no ancient either.
I will try to find a way to work around this work thru the os installation will be my first step
Then working around gui glitches and other issues on hopefully working system.
I got 3 suspects
- Nvidia drivers are not great
- Working with dual monitors is the issue because … see point 1
- Exact subversion of kde 6 that is shipped with Om 6 may be the issue here. I will try to test different desktops
- All above may be true
Shit I see no manual on how to start installer in cli mode desktop nor server
