Old Vanilla forum (forums.openmandriva.org) will be closed and archived for documentation. Currently, there is an alert about the certificate due to the format of the url (4 levels). It should be fixed soon.
Mozilla persona “will be decommissioned” at the end of november. So we started to implement a SSO system with lemonldap. The problem is that we cannot use both SSO and genuine discourse authentication at the same time. So we have to do tests before.
Password lenght: we use the default settings.
users: 10 characters
admins: 15 characters
Currently, there is no possibility to do other checks.
Though the password length should be at least 12 nowadays, I, personally, have no objection to reduce the minimum to 8.
I have forgotten that I am an admin. Need to be more careful…
Not sure if there has been similar complain from users. If yes we may need to rethink about it.
You’re right. I don’t mind if a user wants to use an 8 characters length password, but yes, the admin password must be strong. In this case, an admin must be aware of what a good password is.
We have nothing to automatically check this but can recommend to new admins to use some pwd generator like the excellent pwgen.
