OMG Partition error
OMG Partition error. Installer is detecting partitions in wrong way.
sda7 is root = Currently Wrong
sda8 is Linux Swap = OK
sda9 is Home = Currently Wrong
That is how I select Partition.
But installer is formatting and identifying wrongly.
I saw this is fixed before. But it is generating again.
I selected proper mount Points too.
When are you going to fix this and give us a new OM LX 3.02 ISO for us to install…?
@pujithadimuthu Hi, can you please check outupt from these console commands:
parted /dev/sda print
and
fdisk -l
You could run ISO in ‘Live’ and show screen shots of what you think Installer is doing wrong.
We’ll get our full time paid staff working on this right away.
They have sent me a report right now saying that they want a salary increase.
We need to find the money now…
OMG not a strike, not now, aw man…
I haven’t interpreted it as a request but simply as a question.
Getting back to users question. pujithadimuthu if you want help with this you need to provide all the information requested in post 2 by @TPG and post 3 by @ben79.
Lx 3.02 ISO was released June 21, 2017 there isn’t going to be another one released as far as I know.
Did you use automatic feature in Calamares? You may set mount point by hand in case.
[dimuthu@localhost ~]$ su - root
Password:
[root@localhost ~]# parted /dev/sda print
Model: ATA TOSHIBA DT01ACA0 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 106MB 105MB primary ntfs boot
2 106MB 105GB 105GB primary ntfs
3 105GB 204GB 98.8GB primary ntfs
4 204GB 500GB 296GB extended lba
5 204GB 302GB 98.8GB logical ntfs
6 302GB 401GB 98.8GB logical ntfs
7 401GB 469GB 68.2GB logical ext4
8 469GB 481GB 11.5GB logical linux-swap(v1)
9 481GB 500GB 19.1GB logical ext4
[root@localhost ~]# fdisk -l
Disk /dev/ram0: 31.3 MiB, 32768000 bytes, 64000 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram2: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram3: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram4: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram5: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram6: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram7: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram8: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram9: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram10: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram11: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram12: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram13: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram14: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/ram15: 31.3 MiB, 32768000 bytes, 64000 sectors
Disk /dev/sda: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
Disk identifier: 0x9374b547
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 206847 204800 100M 7 HPFS/NTFS/exFAT
/dev/sda2 206848 204802047 204595200 97.6G 7 HPFS/NTFS/exFAT
/dev/sda3 204802048 397793279 192991232 92G 7 HPFS/NTFS/exFAT
/dev/sda4 397795326 976771071 578975746 276.1G f W95 Ext’d (LBA)
/dev/sda5 397795328 590786559 192991232 92G 7 HPFS/NTFS/exFAT
/dev/sda6 590788608 783779839 192991232 92G 7 HPFS/NTFS/exFAT
/dev/sda7 783781888 916891647 133109760 63.5G 83 Linux
/dev/sda8 916893696 939419647 22525952 10.8G 82 Linux swap / Solaris
/dev/sda9 939421696 976771071 37349376 17.8G 83 Linux
Partition 4 does not start on physical sector boundary.
[root@localhost ~]#
Used manual Partition. I do not use automatic…
You could try to install OMLx only on sda7 (not using /home partition) and if everything is fine, you will be able to mount the home partition later with the command line.
As you wish
When you perform manual partition you may manually select the mount point.
Here is an axample with mcc
and here with calamares
This is independent on weather you format the partition or not.
