Ben, this is useful information.
It turned out to install the system after remove the driver /usr/lib64/xorg/modules/drivers/modesetting_drv.so
To do this, you need to run the Live installation in normal mode, then press Escape so that there is no logo. When the installation hangs at “Terminate Plymouth Boot Screen”, press Alt+F2 to open a new window from the command line. Then enter root login, run mc commander and uninstall this driver. In this case, the windows must constantly change, otherwise nothing will work.
I also needed to change the minimum allowed RAM size in /etc/calamares/modules/welcome.conf > requiredRam=1.0
After installing the system to the disk, you will need to remove this driver again by repeating the above steps.
Notice: The ‘nouveau_drv.so’ driver does not need to be installed. The system completely freezes with it.
New log:
[ 44.370] (--) Log file renamed from "/var/log/Xorg.pid-638.log" to "/var/log/Xorg.0.log"
[ 44.411] (WW) Failed to open protocol names file lib64/xorg/protocol.txt
[ 44.414]
X.Org X Server 1.20.10
X Protocol Version 11, Revision 0
[ 44.414] Build Operating System: Linux OpenMandriva
[ 44.414] Current Operating System: Linux user-pc 5.9.14-desktop-2omv4002 #1 SMP PREEMPT Sat Dec 12 18:48:00 UTC 2020 x86_64
[ 44.414] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9.14-desktop-2omv4002 root=UUID=ba7e700a-3945-47ec-a9a8-ee90ba52990e ro quiet splash logo.nologo acpi_osi=Linux "acpi_osi=!Windows 2012" acpi_backlight=vendor audit=0 rd.timeout=120 scsi_mod.use_blk_mq=1 dm_mod.use_blk_mq=1 rd.systemd.show_status=0 systemd.show_status=0
[ 44.414] Build Date: 02 December 2020 12:10:20AM
[ 44.414] Build ID: x11-server 1.20.10-1
[ 44.414] Current version of pixman: 0.40.0
[ 44.414] Before reporting problems, check https://issues.openmandriva.org
to make sure that you have the latest version.
[ 44.414] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 44.414] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Dec 18 14:15:49 2020
[ 44.461] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 44.461] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 44.524] (==) No Layout section. Using the first Screen section.
[ 44.524] (==) No screen section available. Using defaults.
[ 44.524] (**) |-->Screen "Default Screen Section" (0)
[ 44.524] (**) | |-->Monitor "<default monitor>"
[ 44.524] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 44.524] (==) Automatically adding devices
[ 44.524] (==) Automatically enabling devices
[ 44.524] (==) Automatically adding GPU devices
[ 44.524] (==) Automatically binding GPU devices
[ 44.524] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 44.524] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 44.524] (**) ModulePath set to "/usr/lib64/xorg/extra-modules,/usr/lib64/xorg/modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 44.524] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 44.524] (II) Module ABI versions:
[ 44.525] X.Org ANSI C Emulation: 0.4
[ 44.525] X.Org Video Driver: 24.1
[ 44.525] X.Org XInput driver : 24.1
[ 44.525] X.Org Server Extension : 10.0
[ 44.551] (++) using VT number 1
[ 44.551] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 44.554] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 44.573] (--) PCI:*(0@0:5:0) 10de:0242:1565:1401 rev 162, Mem @ 0xfc000000/16777216, 0xd0000000/268435456, 0xfb000000/16777216, BIOS @ 0x????????/131072
[ 44.577] (II) Open ACPI successful (/var/run/acpid.socket)
[ 44.577] (II) LoadModule: "glx"
[ 44.668] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 45.004] (II) Module glx: vendor="X.Org Foundation"
[ 45.004] compiled for 1.20.10, module version = 1.0.0
[ 45.004] ABI class: X.Org Server Extension, version 10.0
[ 45.006] (==) Matched nouveau as autoconfigured driver 0
[ 45.006] (==) Matched nv as autoconfigured driver 1
[ 45.006] (==) Matched modesetting as autoconfigured driver 2
[ 45.006] (==) Matched fbdev as autoconfigured driver 3
[ 45.006] (==) Matched vesa as autoconfigured driver 4
[ 45.006] (==) Assigned the driver to the xf86ConfigLayout
[ 45.006] (II) LoadModule: "nouveau"
[ 45.025] (WW) Warning, couldn't open module nouveau
[ 45.025] (EE) Failed to load module "nouveau" (module does not exist, 0)
[ 45.025] (II) LoadModule: "nv"
[ 45.025] (WW) Warning, couldn't open module nv
[ 45.025] (EE) Failed to load module "nv" (module does not exist, 0)
[ 45.026] (II) LoadModule: "modesetting"
[ 45.026] (WW) Warning, couldn't open module modesetting
[ 45.026] (EE) Failed to load module "modesetting" (module does not exist, 0)
[ 45.026] (II) LoadModule: "fbdev"
[ 45.026] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 45.044] (II) Module fbdev: vendor="X.Org Foundation"
[ 45.044] compiled for 1.20.4, module version = 0.5.0
[ 45.044] Module class: X.Org Video Driver
[ 45.044] ABI class: X.Org Video Driver, version 24.0
[ 45.044] (II) LoadModule: "vesa"
[ 45.044] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 45.069] (II) Module vesa: vendor="X.Org Foundation"
[ 45.069] compiled for 1.20.9, module version = 2.5.0
[ 45.069] Module class: X.Org Video Driver
[ 45.069] ABI class: X.Org Video Driver, version 24.1
[ 45.069] (II) FBDEV: driver for framebuffer: fbdev
[ 45.070] (II) VESA: driver for VESA chipsets: vesa
[ 45.070] (II) Loading sub module "fbdevhw"
[ 45.070] (II) LoadModule: "fbdevhw"
[ 45.070] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 45.078] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 45.078] compiled for 1.20.10, module version = 0.0.2
[ 45.078] ABI class: X.Org Video Driver, version 24.1
[ 45.078] (**) FBDEV(0): claimed PCI slot 0@0:5:0
[ 45.078] (II) FBDEV(0): using default device
[ 45.079] (II) FBDEV(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 45.079] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 45.079] (==) FBDEV(0): RGB weight 888
[ 45.079] (==) FBDEV(0): Default visual is TrueColor
[ 45.079] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 45.079] (II) FBDEV(0): hardware: nouveaudrmfb (video memory: 4224kB)
[ 45.079] (II) FBDEV(0): checking modes against framebuffer device...
[ 45.079] (II) FBDEV(0): checking modes against monitor...
[ 45.079] (II) FBDEV(0): Virtual size is 1366x768 (pitch 1366)
[ 45.079] (**) FBDEV(0): Built-in mode "current"
[ 45.079] (==) FBDEV(0): DPI set to (96, 96)
[ 45.079] (II) Loading sub module "fb"
[ 45.079] (II) LoadModule: "fb"
[ 45.079] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 45.089] (II) Module fb: vendor="X.Org Foundation"
[ 45.089] compiled for 1.20.10, module version = 1.0.0
[ 45.089] ABI class: X.Org ANSI C Emulation, version 0.4
[ 45.089] (**) FBDEV(0): using shadow framebuffer
[ 45.089] (II) Loading sub module "shadow"
[ 45.089] (II) LoadModule: "shadow"
[ 45.089] (II) Loading /usr/lib64/xorg/modules/libshadow.so
[ 45.094] (II) Module shadow: vendor="X.Org Foundation"
[ 45.094] compiled for 1.20.10, module version = 1.1.0
[ 45.094] ABI class: X.Org ANSI C Emulation, version 0.4
[ 45.094] (II) UnloadModule: "vesa"
[ 45.094] (II) Unloading vesa
[ 45.172] (==) FBDEV(0): Backing store enabled
[ 45.173] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 45.180] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 45.180] (==) FBDEV(0): DPMS enabled
[ 45.180] (II) Initializing extension Generic Event Extension
[ 45.180] (II) Initializing extension SHAPE
[ 45.180] (II) Initializing extension MIT-SHM
[ 45.180] (II) Initializing extension XInputExtension
[ 45.195] (II) Initializing extension XTEST
[ 45.195] (II) Initializing extension BIG-REQUESTS
[ 45.195] (II) Initializing extension SYNC
[ 45.195] (II) Initializing extension XKEYBOARD
[ 45.195] (II) Initializing extension XC-MISC
[ 45.195] (II) Initializing extension SECURITY
[ 45.203] (II) Initializing extension XFIXES
[ 45.203] (II) Initializing extension RENDER
[ 45.203] (II) Initializing extension RANDR
[ 45.203] (II) Initializing extension COMPOSITE
[ 45.203] (II) Initializing extension DAMAGE
[ 45.203] (II) Initializing extension MIT-SCREEN-SAVER
[ 45.203] (II) Initializing extension DOUBLE-BUFFER
[ 45.203] (II) Initializing extension RECORD
[ 45.203] (II) Initializing extension DPMS
[ 45.203] (II) Initializing extension Present
[ 45.203] (II) Initializing extension DRI3
[ 45.203] (II) Initializing extension X-Resource
[ 45.203] (II) Initializing extension XVideo
[ 45.203] (II) Initializing extension XVideo-MotionCompensation
[ 45.203] (II) Initializing extension GLX
[ 45.203] (II) AIGLX: Screen 0 is not DRI2 capable
[ 49.774] (II) IGLX: Loaded and initialized swrast
[ 49.774] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 49.774] (II) Initializing extension XFree86-VidModeExtension
[ 49.774] (II) Initializing extension XFree86-DGA
[ 49.774] (II) Initializing extension XFree86-DRI
[ 49.774] (II) Initializing extension DRI2
[ 50.672] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 50.672] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 50.672] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 50.672] (**) Power Button: Applying InputClass "system-keyboard"
[ 50.672] (**) Power Button: Applying InputClass "touchpad catchall"
[ 50.672] (**) Power Button: Applying InputClass "keyboard defaults"
[ 50.672] (II) LoadModule: "libinput"
[ 50.673] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 50.764] (II) Module libinput: vendor="X.Org Foundation"
[ 50.764] compiled for 1.20.9, module version = 0.30.0
[ 50.764] Module class: X.Org XInput Driver
[ 50.764] ABI class: X.Org XInput driver, version 24.1
[ 50.764] (II) Using input driver 'libinput' for 'Power Button'
[ 50.764] (**) Power Button: always reports core events
[ 50.764] (**) Option "Device" "/dev/input/event3"
[ 50.764] (**) Option "_source" "server/udev"
[ 50.840] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 50.840] (II) event3 - Power Button: device is a keyboard
[ 50.841] (II) event3 - Power Button: device removed
[ 50.843] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 50.843] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 50.843] (**) Option "xkb_layout" "us"
[ 50.843] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 50.912] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 50.912] (II) event3 - Power Button: device is a keyboard
[ 50.914] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 50.914] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 50.914] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 50.914] (**) Power Button: Applying InputClass "system-keyboard"
[ 50.914] (**) Power Button: Applying InputClass "touchpad catchall"
[ 50.914] (**) Power Button: Applying InputClass "keyboard defaults"
[ 50.914] (II) Using input driver 'libinput' for 'Power Button'
[ 50.914] (**) Power Button: always reports core events
[ 50.914] (**) Option "Device" "/dev/input/event1"
[ 50.914] (**) Option "_source" "server/udev"
[ 50.915] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 50.916] (II) event1 - Power Button: device is a keyboard
[ 50.916] (II) event1 - Power Button: device removed
[ 50.918] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 50.918] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 50.918] (**) Option "xkb_layout" "us"
[ 50.918] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 50.920] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 50.920] (II) event1 - Power Button: device is a keyboard
[ 50.921] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 50.921] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 50.921] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 50.921] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 50.921] (**) Sleep Button: Applying InputClass "touchpad catchall"
[ 50.921] (**) Sleep Button: Applying InputClass "keyboard defaults"
[ 50.921] (II) Using input driver 'libinput' for 'Sleep Button'
[ 50.921] (**) Sleep Button: always reports core events
[ 50.921] (**) Option "Device" "/dev/input/event2"
[ 50.921] (**) Option "_source" "server/udev"
[ 50.923] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 50.923] (II) event2 - Sleep Button: device is a keyboard
[ 50.923] (II) event2 - Sleep Button: device removed
[ 50.925] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 50.925] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 50.925] (**) Option "xkb_layout" "us"
[ 50.925] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 50.927] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 50.927] (II) event2 - Sleep Button: device is a keyboard
[ 50.929] (II) config/udev: Adding input device A4Tech USB Mouse (/dev/input/event4)
[ 50.929] (**) A4Tech USB Mouse: Applying InputClass "evdev pointer catchall"
[ 50.929] (**) A4Tech USB Mouse: Applying InputClass "libinput pointer catchall"
[ 50.929] (**) A4Tech USB Mouse: Applying InputClass "touchpad catchall"
[ 50.929] (II) Using input driver 'libinput' for 'A4Tech USB Mouse'
[ 50.929] (**) A4Tech USB Mouse: always reports core events
[ 50.929] (**) Option "Device" "/dev/input/event4"
[ 50.929] (**) Option "_source" "server/udev"
[ 50.985] (II) event4 - A4Tech USB Mouse: is tagged by udev as: Mouse
[ 50.986] (II) event4 - A4Tech USB Mouse: device is a pointer
[ 50.987] (II) event4 - A4Tech USB Mouse: device removed
[ 50.992] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:0b.0/usb2/2-6/2-6:1.0/0003:09DA:000A.0001/input/input4/event4"
[ 50.992] (II) XINPUT: Adding extended input device "A4Tech USB Mouse" (type: MOUSE, id 9)
[ 50.993] (**) Option "AccelerationScheme" "none"
[ 50.993] (**) A4Tech USB Mouse: (accel) selected scheme none/0
[ 50.993] (**) A4Tech USB Mouse: (accel) acceleration factor: 2.000
[ 50.993] (**) A4Tech USB Mouse: (accel) acceleration threshold: 4
[ 51.050] (II) event4 - A4Tech USB Mouse: is tagged by udev as: Mouse
[ 51.051] (II) event4 - A4Tech USB Mouse: device is a pointer
[ 51.054] (II) config/udev: Adding input device A4Tech USB Mouse (/dev/input/mouse0)
[ 51.055] (**) A4Tech USB Mouse: Applying InputClass "touchpad catchall"
[ 51.055] (II) No input driver specified, ignoring this device.
[ 51.055] (II) This device may have been added with another device file.
[ 51.056] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 51.057] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 51.057] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 51.057] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 51.057] (**) AT Translated Set 2 keyboard: Applying InputClass "touchpad catchall"
[ 51.057] (**) AT Translated Set 2 keyboard: Applying InputClass "keyboard defaults"
[ 51.057] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 51.057] (**) AT Translated Set 2 keyboard: always reports core events
[ 51.057] (**) Option "Device" "/dev/input/event0"
[ 51.057] (**) Option "_source" "server/udev"
[ 51.061] (II) event0 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 51.061] (II) event0 - AT Translated Set 2 keyboard: device is a keyboard
[ 51.062] (II) event0 - AT Translated Set 2 keyboard: device removed
[ 51.065] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 51.065] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[ 51.065] (**) Option "xkb_layout" "us"
[ 51.065] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 51.069] (II) event0 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 51.069] (II) event0 - AT Translated Set 2 keyboard: device is a keyboard
[ 159.842] (EE) event4 - A4Tech USB Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 170.089] (EE) event4 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 172.672] (EE) event4 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 176.441] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 176.442] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 285.569] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[ 293.686] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
