DE: KDE Plasma 6.3.4, WM: KWin (X11)
Clean install today.
om-welcome starts but immediately quits, when I run it in term I see:
$ om-welcome
GBM is not supported with the current configuration. Fallback to Vulkan rendering in Chromium.
$ coredumpctl dump om-welcome
No match found.
Ram memory check to rule out bad RAM, all OK.
$ lspci | grep VGA
2d:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3080 Ti] (rev a1)
$ lsmod | grep video
video 73728 1 nouveau
OS: OpenMandriva Lx 6.0 (Vanadium) Rock x86_64
Host: MS-7C37 (1.0)
Kernel: Linux 6.14.2-desktop-3omv2590
Uptime: 2 hours, 3 mins
Packages: 2204 (rpm), 12 (flatpak)
Shell: bash 5.2.37
Display (HP X34): 3440x1440 @ 100 Hz in 34" [External]
WM: KWin (X11)
WM Theme: Breeze
Theme: Breeze (Light) [Qt], Breeze [GTK2/3]
Icons: breeze [Qt], breeze [GTK2/3/4]
Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
Cursor: Breeze_Light (24px)
Terminal: konsole 25.4.0
CPU: AMD Ryzen 9 5900X (24) @ 5.72 GHz
GPU: NVIDIA GeForce RTX 3080 Ti [Discrete]
Memory: 4.04 GiB / 62.73 GiB (6%)
Swap: 0 B / 77.00 GiB (0%)
Disk (/): 17.27 GiB / 165.46 GiB (10%) - ext4
Local IP (wlp47s0f3u2): 10.0.0.57/24
Locale: en_US.UTF-8
From searching, it seems this has been an issue for a very long time.
Thanks, regards.
$ om-welcome
No match found.
First guess would be that. Not positive but I suspect this has been reported a number of times. Perhaps people that actually have nVidia crap would have some suggestion?
You could run coredumpctl and see if /usr/bin/om-welcome is listed. If it isn’t then what would anyone work on? Also go to OM-Chat and ask developers what this means GBM is not supported with the current configuration. Fallback to Vulkan rendering in Chromium. The second part about Chromium seems completely irrelevant to me but what do I know? The first part sort of makes me wonder if users with nvidia hardware need to install some vulkan package or if such a package should be in Requires for 'nouveau` driver and maybe the proprietary drivers as well.
Is your hardware supported by the proprietary nvidia driver OM provides?
