Salve, ho il seguente errore in Virtualbox se tento di aggiornare OM P6 Cooker:
Running transaction check
Transaction check succeeded.
Running transaction test
You can remove cached packages by executing ‘dnf clean packages’.
Error: Transaction test error:
file /usr/lib/firmware/intel/sof-tplg from install of sof-bin-2024.03-1.x86_64 conflicts with file from package sof-firmware-2.2.6-1.noarch
Come posso risolvere?
Inoltre telegram crasha con questo messaggio:
[live@omv-2933 ~]$ telegram-desktop
MESA-LOADER: failed to open zink: /usr/lib64/dri/zink_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib64/dri, suffix _dri)
failed to load driver: zink
QPainter::begin: Paint device returned engine == 0, type: 2
QWidget::render: Cannot render with an inactive painter
qt.gui.icc: fromIccProfile: failed minimal tag size sanity
As temporary workaround try:
dnf remove sof-firmware && dnf install sof-bin
