I already know that one, there are 2, performance and powersave. The issue seems to be that tuned.service doesn’t use either one and the default set-up in OM Lx 3 has cpupower disabled. Which is why the work around described here is designed to allow cpupower to govern the CPU and tuned to govern everything else that it normally governs. Post edit:If there is a way to do this with tuned I haven’t found it and no one is telling me.
Again with the default set-up in OM Lx 3 this computer and a notebook (with older Intel CPU) the CPU frequency is at or very near maximum all the time. That does not seem like a good thing to me. Would think other users with Intel CPU’s would want to check this and if they find the same results I do maybe give some thought/research to whether this is OK with them.
With cpupower.service enabled the powersave governor works just fine. The issue is that it does not work at all with default OM Lx 3 settings. That is because with default OM Lx 3 settings cpupower.service does not and can not work.
OK right now I’m in a freshly installed default install of Lx 3.03 fully updated no testing repos.
$ systemctl status cpupower.service
● cpupower.service - Configure CPU power related settings
Loaded: loaded (/lib/systemd/system/cpupower.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Notice that cpupower.service is enabled but inactive (dead). Why? Because there is set a Conflicts in tuned.service. This is from my OM Lx 3 default ‘/lib/systemd/system/tuned.service’:
Thanks @mandian. FWIW: This is a quote form the link @mandian provided:
“The intel_pstate driver knows the details of the how the CPU works and it does a better job than the generic ACPI solution”
"intel_pstate offers only two governors, powersave and performance. Intel claims that the intel_pstate “powersave” is faster than the generic acpi governor with “performance”
otherwise I can do anything and everything in that article and it won’t matter unless I manually intervene and enable cpupower.service.
Post edit: And both computers I’m talking about use intel_pstate for CPU driver. I discovered that long ago.
Thanks @mandian. Here is what that wiki page says about cpupower (italics added by me):
"cpupower
cpupower is a set of userspace utilities designed to assist with CPU frequency scaling. The package is not required to use scaling, but is highly recommended because it provides useful command-line utilities and a systemd service to change the governor at boot.
The configuration file for cpupower is located in /etc/default/cpupower. This configuration file is read by a bash script in /usr/lib/systemd/scripts/cpupower which is activated by systemd with cpupower.service. You may want to enable cpupower.service to start at boot."
Which is what the workaround I got from Gabriel Craciunescu does. It enables cpupower.service to work from boot in OM Lx 3.03.
Post edit: I’ve done a lot of reading on this issue. It is my understanding currently that The intel-pstate powersave mode should be the equivalent of the acpi-cpufreq ondemand mode. Also the acpi-cpufreq is a driver for older hardware as in the ondemand governor. The workaround I am using has the advantage that it is based on the CPU manufacturers design and specifications.
