[x I have Searched the forum for my issue and found nothing related or helpful
OpenMandriva Lx release 6.0 (Vanadium) Rock for znver1
KDE, on x11
So in this post:
the problem is described for the wayland system.
Well, on Rock the problem is still there. Tested on my primary desktop (amd) and on my test system (intel i7-6700; Dell Optiplex 3040)
And yes, the same solution (running with sudo from the cli does work).
I’m documenting this here because a new user is more likely going to use the gui/menu rather than the cli. So we really should fix it.
On ROME (iso 4172 with full updates) it was working fine
