Om-imagewriter-2.6.4.2-1.znver1 won't open in Wayland
  • OpenMandriva Lx version: OS: OpenMandriva Lx 24.12 (ROME) Rolling x86_64
  • Desktop environment (KDE, LXQT…): KDE Plasma 6.2.5
  • Description of the issue (screenshots if relevant): om-imagewriter-2.6.4.2-1.znver1 won’t open in Wayland
Operating System: OpenMandriva ROME 24.12
KDE Plasma Version: 6.2.5
KDE Frameworks Version: 6.10.0
Qt Version: 6.8.1
Kernel Version: 6.12.9-desktop-1omv2490 (64-bit)
Graphics Platform: Wayland
Processors: 24 × AMD Ryzen 9 7900X 12-Core Processor
Memory: 30.6 GiB of RAM
Graphics Processor: AMD Radeon Graphics
Manufacturer: ASUS
It asks for the root password, but once that box goes away, the program does not open. I checked on the other PC and got the same result.
I logged out and went to the Failsafe X session and started the program from the command line and it worked just fine. I burned my Windows 11 ISO to the thumbdrive and logged back in on Wayland. My task is done, but I can still test for you if needed.
It probably needs to be rebuilt.
FWIW in Cooker Wayland works not on my box.
[ben79@3312 ~]$ om-imagewriter
[ben79@3312 ~]$ rpm -qa | grep om-image
Looks like in journal log it takes a dump without real output:
Jan 17 16:58:27 3312 su[9446]: (to root) ben79 on pts/2
Jan 17 16:58:27 3312 systemd-logind[960]: New session c17 of user root.
Jan 17 16:58:27 3312 systemd[1]: Started session-c17.scope - Session c17 of User root.
Jan 17 16:58:27 3312 su[9446]: pam_unix(su:session): session opened for user root(uid=0) by (uid=1001)
Jan 17 16:58:27 3312 systemd-coredump[9468]: Process 9465 (om-imagewriter) of user 0 terminated abnormally with signal 6/ABRT, processing...
Jan 17 16:58:27 3312 systemd[1]: Started systemd-coredump@1-9468-0.service - Process Core Dump (PID 9468/UID 0).
Jan 17 16:58:27 3312 systemd[1]: Started drkonqi-coredump-processor@1-9468-0.service - Pass systemd-coredump journal entries to relevant user for potential DrKonqi ha>
Jan 17 16:58:27 3312 wireplumber[9434]: [0:10:35.299568260] [9434]  WARN IPAManager ipa_manager.cpp:148 No IPA found in '/usr/lib64/libcamera'
Jan 17 16:58:27 3312 wireplumber[9434]: [0:10:35.299580543] [9434]  INFO Camera camera_manager.cpp:327 libcamera v0.4.0
Jan 17 16:58:27 3312 systemd-coredump[9469]: Resource limits disable core dumping for process 9465 (om-imagewriter).
Jan 17 16:58:27 3312 systemd-coredump[9469]: [🡕] Process 9465 (om-imagewriter) of user 0 terminated abnormally without generating a coredump.
Jan 17 16:58:27 3312 systemd[1]: systemd-coredump@1-9468-0.service: Deactivated successfully.
Jan 17 16:58:27 3312 systemd[1]: session-c17.scope: Deactivated successfully.
Jan 17 16:58:27 3312 su[9446]: pam_unix(su:session): session closed for user root
Jan 17 16:58:27 3312 systemd-logind[960]: Session c17 logged out. Waiting for processes to exit.
Jan 17 16:58:27 3312 systemd-logind[960]: Removed session c17.
I tried the rebuild in Cooker and that still works not in Wayland on my box.
Summary: Opens in X11 not in Wayland
x86_64 is also not affected. I can open it on both X11 and Wayland.
Should have mentioned my laptop is znver1.
Which means this needs a bug report.
Bug reported.
I just tested this again and it will open with…
sudo om-imagewriter
without the sudo, it opens the password box, and disappears after with no error message in the terminal. I have not gone as far as digging through logs.
