As of today it should be OK for users to upgrade their OM Lx 4 systems.
Not everyone will have the same or all of the errors mentioned, you only need to take the steps that address the errors that occur on your system. If you don’t see any errors, then don’t worry, be happy and upgrade as you normally do. That is if you normally use the command line to upgrade. Dnfdragora or Discover upgrades are still not recommended. (Seriously don’t do that.)
It is impossible to anticipate every possible problem on any Linux distro with upgrading however it is likely that a lot of users will see something like this:
$ sudo dnf clean all
$ sudo dnf --refresh upgrade
OpenMandriva Cooker - x86_64 - non-free 126 kB/s | 161 kB 00:01
OpenMandriva Cooker - x86_64 - Restricted 114 kB/s | 141 kB 00:01
OpenMandriva Cooker - x86_64 2.7 MB/s | 14 MB 00:05
Error:
Problem 1: cannot install the best update candidate for package gstreamer1.0-plugins-bad-1.14.4-2.x86_64
- nothing provides libfluidsynth.so.1()(64bit) needed by gstreamer1.0-plugins-bad-1.14.4-2.x86_64
Problem 2: cannot install both kwave-19.04.0-2.x86_64 and kwave-1:18.12.3-1.x86_64
- package kwave-19.04.0-2.x86_64 obsoletes kwave < 1:19.04.01-2 provided by kwave-1:18.12.3-1.x86_64
- cannot install the best update candidate for package lib64kwave18-1:18.12.3-1.x86_64
- problem with installed package kwave-1:18.12.3-1.x86_64
Problem 3: cannot install both libqalculate-data-3.1.0-1.noarch and libqalculate-data-2.9.0-1.noarch
- package lib64qalculate20-2.9.0-1.x86_64 requires libqalculate-data = 2.9.0-1, but none of the providers can be installed
- cannot install the best update candidate for package libqalculate-data-2.9.0-1.noarch
- problem with installed package lib64qalculate20-2.9.0-1.x86_64
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
To get past these:
Problem 1:
Download from Index of /cooker/repository/x86_64/main/release/ gstreamer1.0-plugins-bad.
Next we are going to remove and then install gstreamer1.0-plugins-bad like this:
$ sudo rpm -e --nodeps gstreamer1.0-plugins-bad
Next we cd to the directory where you downloaded gstreamer1.0-plugins-bad perhaps this:
$ cd /home/<uname>/Downloads
Now install the new gstreamer1.0-plugins-bad:
$ sudo rpm -ihv --nodeps gstreamer1.0-plugins-bad-1.16.0-1-omv4000.x86_64.rpm
That should take care of Problem 1 if you have it.
Problem 2 and Problem 3 if you have them:
Now just as a one time thing we will add an option (–allowerasing) to normal upgrade command. This will remove the offending packages in problems 2 & 3 and install their updated replacements:
$ sudo dnf --refresh --allowerasing upgrade
Then to be sure we got everything:
And that should do the job. It is a good idea to periodically run ‘dnf autoremove’ to remove any packages that were installed as dependencies but are no longer used.
It is always a good practice to run ‘dnf clean all’ before doing any package management from command line. Among other things this cleans the cache to ensure that you are installing the most recent packages. Also helps to eliminate confusion some times. So do it.
