is there a way to install Nvidia driver on 5.11.12-desktop-1omv4002 kernel?
Actually I can’t find it on official rock repositories.
Thank you for your support.
for devs
there is 2 ways
- wait good nouveau version re-clocked ( old videocard nvidia)
- try to have with Kde & Wayland - wroots working with nvidia version 470 drivers ( others cards videos nvidia )
I do not have nVidia hardware thus I cannot test the driver software. I can test whether the OM Lx packages will install but that is all.
Yes, install the driver that works with that kernel version and your nVidia hardware from nVidia website or legacy site. Any questions about doing this you should ask at the nVidia Linux forum. One may also find numerous tutorials for this with an internet search.
Remember that nVidia proprietary drivers are not only hardware specific but kernel specific. If you install a new kernel version you will need to install a new driver package. Everytime.
OpenMandriva Lx 4.2 packaged nvidia drivers only work with kernel 5.10.14 or 5.7.7. I can not explain this.
I would imagine users find OpenMandriva’s support for nVidia hardware confusing. Officially OM supports only the opensource nouveau driver. This is stated here. There is one part time Community Contributor, @Colin, that tries to make the proprietary drivers available from time to time. As I understand things there will be no new packages for OM Lx 4.2.
In any version of OpenMandriva Lx any nVidia proprietary drivers will be in non-free repository. This command will show what is available:
$ dnf search nvidia
A recommended alternative would be for user to upgrade to OM Lx Rolling where one would have a choice of:
$ sudo dnf install nvidia
Which will install nvidia-465.27 and also kernel 5.12.4. That is a much more recent kernel than 5.11.12.
Or:
$ sudo dnf install nvidia-390
Which surprisingly works with 5.12.7 which is the most recent kernel version available for Rolling.
Hope this information is helpful to @Marco and other users.
I’m in the process of rebuilding some packages for Lx 4.2 and Rolling. I will post another thread when I get things sorted and get the commands straight and tested. Working with nvidia packages is complicated and sometimes downright irritating.
I realize that dealing with proprietary software is just annoying, but don’t understand why Nvidia drivers are available for the newest kernels in Rolling while they are not for the older, stable kernels in Rock.
I thought Rock repository was more complete than Rolling. Maybe I have not clear the difference between them.
They are available in Rock, I just built them a few days ago.
Also the kernels in Rolling are newer but they are also stable. We can not add new kernels to Lx 4.2 because the tool-chain packages are to old. OM generally does not change any tool-chain packages in our stable release.
Thank you so much, Ben!
I confirm Nvidia driver for kernel 5.11.12 work fine.
Great work! I look forward to getting the 4.3 release.
Thanks for the feed back. It helps.
https://forum.openmandriva.org/t/progress-on-om-lx-4-3-release/4124/3
