Num lock on boot
This seems to be a minor problem, and there seems to be a italian post mentioning it but unfortunately I don’t understand italian …
When the system is booted, NUMLOCK key is always on in OMV LX 3.0. Thus, for laptops with “shared keys”, often login problems arise since password is not correct.
OMV 2014 and older did not have this default.
Is there a way to change this default?
Thanks
you can change here:
systemsettings => hardware => input devices => NumLock on KDE Startup
sorry too fast reading
You can change this in /etc/sddm.conf
# Initial NumLock state
# Valid values: on|off|none
# If property is set to none, numlock won’t be changed
Numlock=on
Now it is OK. Thanks
