We now have our own OM palette colorscheme for Konsole. The file name is OpenMandriva.colorscheme and you can get it at my GitHub.
Ctl+Shft+s to download the file
Make sure it goes to your Downloads folder and open the folder in Dolphin
Right Click the OpenMandriva.colorscheme and select Copy
Go to ~/.local/share/konsole/ and Right-Click Paste
Close Dolphin
Open Konsole
Settings > Edit Current Profile
Click Appearance
You should see OpenMandrivaColors as a choice
Thanks WP. I couldn’t get it to work as the file that downloaded when using “save link as” was in html format. Once I downloaded the Raw file and pasted it konsole, it showed up and worked fine
