zaivala
(Moss Bliss)
June 22, 2019, 8:51pm
1
OM Lx 4 final
KDE
Installation not working
Lenovo T430, 32" Westinghouse TV as monitor
I downloaded the ISO, burned it to a fresh USB stick, and loaded the stick on my computer.
I would also state that my laptop showed that I was on WiFi, whereas the laptop is connected to my router via Ethernet.
ben79
(Ben Bullard)
June 23, 2019, 4:09pm
2
For this could you post output of:
$ nmcli device status
Otherwise the files I ask for here should be enough to get some investigation started on this issue as well.
ben79
(Ben Bullard)
June 23, 2019, 4:27pm
3
Moderator duties:
I split topics from an original post with multiple issues to make the technical issues easier to follow.
Note : To all users we also do this to make it possible for users and developers to find issues when they search the forum.
zaivala
(Moss Bliss)
June 26, 2019, 12:14pm
4
I love it when the developer tells me to post the results of a terminal output when I can’t even get the distro installed. Don’t break up topics until the underlying issue has been solved.
ben79
(Ben Bullard)
June 26, 2019, 2:52pm
5
Please provide info from ‘Live’ ISO. If you have to do so without using TV monitor. Otherwise there is nothing for developers to work on. Post-edit : The:
needs to be run while you are having the issue.
zaivala
(Moss Bliss)
June 27, 2019, 1:56am
6
The. System. Locks. Up. Before. I. Can. Do. Anything. Except. Make. The. TV. Screen. Active.
Before doing that, I cannot see well enough to do anything.
And I repeat, it did not do this with 3.03, 4 Alpha, or 4 Beta.
ben79
(Ben Bullard)
June 27, 2019, 2:11am
7
I’m sure that’s all true. So as matters stand no one has been able to reproduce the issue and without logs there is nothing to work on.
raphael
(Raphaël)
June 27, 2019, 6:30am
8
Isn’t it possible to switch to TTY? (ctrl+alt+F2 or F3…)?
ben79
(Ben Bullard)
Split this topic
June 28, 2019, 6:16am
9
