Need feedback on a Bash scripting tool I made
Hi again :wave:
tl;dr
I made a CLI tool for myself, then finally published it, but didn’t really advertised about. As I know anybody actually using it, I need some feedback. I wish I could keep myself motivated into keeping it going (correct things / validate roadmaps, etc).
Coming from a webDev background (PHP, JS, Rust…) yet loving Bash and the CLI life I was looking for a tool that would let me create/manage/distribute bash scripts and libs like the other languages tooling do.
As I didn’t find it, I made a little one for myself and published it in case it could help others. It’s called Sh:erpa because it helps you carry your packages up the mountain :slight_smile:
With curl, git and gawk installed, we can call…
bash -c "$(curl -sLo- https://sherpa-cli.netlify.app/install.sh)"
It will do the following:
  • A. Install the CLI tools if not already installed.
  • B. Clone the Sh:erpa repo as ~/.sherpa
  • C. Add to the $PATH ~/.sherpa/bin
  • D. Initiate the SherpaCustomDir as ~/sherpa
For the install part, it use ‘webi’ from webinstall.dev
Creating a Bash version of a Crate
# Check the Dashboard
sherpa
# Create a BashBox
sherpa new <scriptName>
This will create a package directory like Cargo is creating the “crate” package, build the script and make it invoquable as scriptName.
# /home/user/sherpa/boxes/myScript
├── data
│   └── file.yaml
├── docs
│   └── myScript.md
├── README.md
├── Sherpa.yaml
├── src
│   ├── bin.sh
│   ├── _globals.sh
│   ├── _header.sh
│   ├── _lib.sh
│   ├── _options.sh
│   └── __paths.txt
├── target
│   └── local
│       └── myScript
└── tests
    └── example_test.sh
It have unit tests, docs generation from comments, options/flags, partials files (for DRY workflow) with a build step putting all together.
A simple src/bin.sh file could look like:
use "std/fmt"
main() {
  # Data
  dude="$(dataGet "hiker" "name")"
  # Template
  h1 "Greetings adventurer :)"
  hr "+" "-" # ------+------
  br
  p  "Welcome ${txtBlue} ${dude} ${x}!"
# Load the main fn if no arguments
[[ "$#" == 0 ]] && main; exit 0
To put it simple, it let us create/manage local scripts & libs, or publisg them and letting people install/update/delete them like a package manager would.
To see all the commands, some links:
Github : SherpaCLI/sherpa
Docs : sherpa-cli.netlify.app
Discord: Invite
You will also find me in the Matrix room, openMandriva’s Chat :wink:
I don’t know if it’s the right forum for that type of posts, but I do hope finding at least one or two people willing to play around with the tool or just share ideas or anything about.
The fact you used “dude” as a variable means I just have to look at this…
I’ll let you know
