Greetings!
2048 was the latest at the time of installation.
Performed manual partitioning and didn’t run into problems with the much-dreaded Calamares.
Installed just fine. It was an offline installation.
Upon installation, went into System Settings and set the system up to my liking (nothing too crazy).
However I found policy kit kinda br… well not functioning properly. It’s kinda hardish to give an accurate description but I shall provide footage on demand.
I knew firewalld was included, hence I looked for a front end to configure it. To my rather not so pleasant surprise, I could only find plasma-firewall which I didn’t find useful at all.
Suggestion: no longer include plasma-firewall into the builds. Include firewall-config instead. I wouldn’t mind if you included firewall-applet as well but the latter is of lesser importance.
I proceeded to fully update the system from Konsole with only the main repository enabled and everything went perfectly well.
I tried to install dnfdrake but failed. Enabled unsuported and was finally able to install it. From Konsole.
Suggestion: no longer include dnfdragora as, in Rome, it serves no useful purpose. I were you, I’d remove even discover. Include dnfdrake into main and into the builds.
As an avid multimedia user that I am, installed k3b. One of the main reasons OpenMandriva had arisen my interest in the first place is that it has the most up-to-date cdrtools (comparatively to other distributions). RIP Joerg Shilling. Noticed that k3b pulled in dvd+rw-tools as well other back ends (if I recall correctly) but not the technically defective abandonware cdrkit of which wodim and genisoimage are part of. I’m yet to find out if there’s any real benefit in growisofs. Just curious why you haven’t opted for a simpler k3b + cdrtools combo. You fused dvd+rw-tools and k3b. There’s no way to remove dvd+rw-tools without removing k3b. IMHO, burning disks is just as old school as using a desktop computer. And no, USB thumb drives and optical media are not interchangeable technologies.
I noticed that you have kuserfeedback implemented in such a way that it’s not even cleanly removable. Some other distributions have not complied it at all. You do have an option to totally get rid of it as well as of all the other nonsense that it comes with. It’s a totally useless piece of junk. Pollutes the hard drive with useless metadata. My kind suggestion is to get rid of it.
I were you, I would also get rid of any and all shortcuts to install software. IMHO the right way is either from the command line or from dnfdrake that is by far the most capable front end that I have ever seen. It’s a gem.
To sum it up, despite some nuisances that are mostly minor, I’ve been having a top experience on build 2048. Wonderful and truly unique, as advertised. Nice community as well. It’s a keeper. Noticed the new build.
Keywords: policy kit, firewall-config, dnfdrake, no hacky shortcuts, top distribution
