Mullvad VPN
  • _**OpenMandriva Lx version current
  • _**Desktop environment All
  • _**Description of the issue Looking for a way to install the Mullvad VPN GUI client. The repo can’t seem to be added for the RPM. Attempts to install the RPM packages fails due to missing dependencies.
I understand that I can manually input the wire guard, but the GUI is so convenient. If I can make that work, that would be the best.
Welcome to OpenMandriva Forum.
Please read How to get better results when posting about problems
It will save yours and other’s time.
Also, you can see a big blue-ish banner at the top of all the forum pages. Have a look at it.
Thank you.
Welcome!
@Tellur1an Report “fails due to missing dependencies” is not useful :wink:
Plase follow the above guidelines and post your console output log (the whole console log).
It’s the only way to get someone look at your problem and hopefully have it solved.
Thanks.
Feb 07 07:02:16 openmandriva-x8664 systemd[1]: Started hw-probe.service - Probe hardware and upload result to Linux hardware database.
Feb 07 07:02:16 openmandriva-x8664 kernel: Non-volatile memory driver v1.3
Feb 07 07:02:16 openmandriva-x8664 kernel: st: Version 20160209, fixed bufsize 32768, s/g segs 256
Feb 07 07:02:16 openmandriva-x8664 kernel: sr 2:0:0:0: Attached scsi generic sg0 type 5
Feb 07 07:02:18 openmandriva-x8664 kernel: Bluetooth: Core ver 2.22
Feb 07 07:02:18 openmandriva-x8664 kernel: NET: Registered PF_BLUETOOTH protocol family
Feb 07 07:02:18 openmandriva-x8664 kernel: Bluetooth: HCI device and connection manager initialized
Feb 07 07:02:18 openmandriva-x8664 kernel: Bluetooth: HCI socket layer initialized
Feb 07 07:02:18 openmandriva-x8664 kernel: Bluetooth: L2CAP socket layer initialized
Feb 07 07:02:18 openmandriva-x8664 kernel: Bluetooth: SCO socket layer initialized
Feb 07 07:02:18 openmandriva-x8664 systemd[1]: Started pcscd.service - PC/SC Smart Card Daemon.
Feb 07 07:02:18 openmandriva-x8664 (pcscd)[39859]: pcscd.service: Referenced but unset environment variable evaluates to an empty string: PCSCD_ARGS
Feb 07 07:02:18 openmandriva-x8664 pcscd[39859]: 00000000 commands.c:1019:CmdEscapeCheck Command not supported or not allowed
Feb 07 07:02:18 openmandriva-x8664 pcscd[39859]: 00000179 commands.c:1019:CmdEscapeCheck Command not supported or not allowed
Feb 07 07:02:18 openmandriva-x8664 pcscd[39859]: 00000154 commands.c:1019:CmdEscapeCheck Command not supported or not allowed
Feb 07 07:02:19 openmandriva-x8664 kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Feb 07 07:02:19 openmandriva-x8664 kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Feb 07 07:02:19 openmandriva-x8664 kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Feb 07 07:02:22 openmandriva-x8664 systemd[1]: hw-probe.service: Deactivated successfully.
Feb 07 07:02:22 openmandriva-x8664 systemd[1]: hw-probe.service: Consumed 2.228s CPU time, 80.4M memory peak.
Feb 07 07:03:08 openmandriva-x8664 appimaged-869-x86_64.AppImage[1424]: 2025/02/07 07:03:08 MQTT client connected: false
Feb 07 07:03:20 openmandriva-x8664 systemd[1]: pcscd.service: Deactivated successfully.
Feb 07 07:04:02 openmandriva-x8664 firefox.desktop[7410]: libx265.so.215: cannot open shared object file: No such file or directory
Feb 07 07:04:02 openmandriva-x8664 firefox.desktop[7410]: libx265.so.215 is missing, x265 support will be disabled
Feb 07 07:04:23 openmandriva-x8664 gnome-shell[1542]: g_closure_unref: assertion 'closure->ref_count > 0' failed
Feb 07 07:04:32 openmandriva-x8664 PackageKit[1663]: uid 1001 is trying to obtain org.freedesktop.packagekit.package-install-untrusted auth (only_trusted:0)
Feb 07 07:04:36 openmandriva-x8664 PackageKit[1663]: uid 1001 obtained auth for org.freedesktop.packagekit.package-install-untrusted
Feb 07 07:04:36 openmandriva-x8664 PackageKit[1663]: install-files transaction /144_eabcbbeb from uid 1001 finished with failed after 480ms
╰─[:(] % sudo rpm -i ~/Downloads/MullvadVPN-2025.2_x86_64.rpm
[sudo] password for tell:
warning: /home/tell/Downloads/MullvadVPN-2025.2_x86_64.rpm: Header V4 RSA/SHA256 Signature, key ID 19c8314c: NOKEY
error: Failed dependencies:
	dbus-libs is needed by mullvad-vpn-2025.2-1.x86_64
	libXScrnSaver is needed by mullvad-vpn-2025.2-1.x86_64
I had the same problem and the community here helped me install it. This post may be able to help you:
