On two occasions when I’ve waked from sleep I’ve had to restart KDE because the panel, desktop background and desktop icons had disappeared. Running systemctl --user restart plasma-plasmashell.service worked at getting everything back.
Open apps are still visible. I already had Konsole open so I am not sure if opening Konsole with the keyboard shortcut will work in order to run that command. Dropping to a TTY would work though.
Hmm, sounds like an upstream problem, maybe try to report to KDE directly. But first, make sure you are using the latest updates. If you are on KDE 5, ROME 6 will drop in a few days and might resolve the problem by bringing final fixes. However, if the problem is still persistent, then once you have updated to ROME 6.0 you can install plasma 6 and uninstall plasma 5. Plasma 6 is much better than 5 with a lot of work put into bug fixes and backend improvement.
This could also be a problem with drivers, your hardware or X11/Wayland. Which one are you using?
