I went ahead and did a coloration of OMLX for Lxqt/Openbox. I will have it available on my github as usual. the Address is GitHub - pastorczo13/LXQTomlx: LXQT OMlx
I will show with and without Picom enabled. I find that you can use it either or. I also have an openbox config file where you you can use ctrl-left or right to tile windows to the left or right. You could essentially do this for up and down respectively, but I choose not to.
