Hello, I am sorry to bother you again so soon
- OpenMandriva Lx version:
5.0 Technical Preview
KDE
I have installed Lutris from the OM Welcome Window. The installation was successful but the program itself won’t run. I have also tried a reinstall through Dnfdrake with the same result.
Starting through the terminal by using the lutris -d command gives this output:
$ lutris -d
File "/usr/bin/lutris", line 52, in <module>
from lutris.gui.application import Application # pylint: disable=no-name-in-module
File "/usr/lib/python3.11/site-packages/lutris/gui/application.py", line 39, in <module>
from lutris.game import Game, export_game, import_game
File "/usr/lib/python3.11/site-packages/lutris/game.py", line 24, in <module>
from lutris.runners import InvalidRunner, import_runner, wine
File "/usr/lib/python3.11/site-packages/lutris/runners/wine.py", line 9, in <module>
from lutris.runners.commands.wine import ( # noqa: F401 pylint: disable=unused-import
File "/usr/lib/python3.11/site-packages/lutris/runners/commands/wine.py", line 16, in <module>
from lutris.util.wine.prefix import WinePrefixManager
File "/usr/lib/python3.11/site-packages/lutris/util/wine/prefix.py", line 4, in <module>
from lutris.util import joypad, system
File "/usr/lib/python3.11/site-packages/lutris/util/joypad.py", line 10, in <module>
import evdev
File "/usr/lib64/python3.11/site-packages/evdev/__init__.py", line 5, in <module>
from evdev.device import DeviceInfo, InputDevice, AbsInfo, EvdevError
File "/usr/lib64/python3.11/site-packages/evdev/device.py", line 12, in <module>
from evdev.eventio_async import EventIO, EvdevError
File "/usr/lib64/python3.11/site-packages/evdev/eventio_async.py", line 63, in <module>
class ReadIterator(object):
File "/usr/lib64/python3.11/site-packages/evdev/eventio_async.py", line 88, in ReadIterator
@asyncio.coroutine
AttributeError: module 'asyncio' has no attribute 'coroutine'. Did you mean: 'coroutines'?
I am not sure how or if I could fix this by myself. Thank you in advance for any help.
