Descrambler ! I get it. This kind of things may occur, when we upgrade to a half-baked version of the system. Even If I used proper, recommended commands to perform the upgrade. It is nobody’s fault but mine. No one forced me to upgrade anything. was officially advised not to do this.
I just found this error / bug funny. Not stressful funny.
… I post that here because I know we are in repos and packages transition, so I do not want to create another unnecessary support entry. I will do a clean install after official OM 6 emerges. I do not want to waste anybody’s time on a problem I basically create on my own.
Anyway, it is kinda funny. I installed no new packages after upgrade to rc 6.
If I use dnf search other-browser then among a bunch of errors that are there for obvious reasons I will get this otter-browser.x86_64 : Web browser controlled by the user, not vice-versa.
But ;D if i go with sudo dnf install otter-browser.x86_64
bash: sudo dnf: nie znaleziono polecenia. Which means sudo dnf command not found.
If I put simply dnf in terminal I will get dnf
usage: dnf [options] COMMAND
Lista głównych poleceń:
alias Wyświetla listę lub tworzy aliasy poleceń
autoremove usuwa wszystkie niepotrzebne pakiety zainstalowane wcześniej jako zależności
check wyszukuje problemy w bazie danych pakietów
check-update wyszukuje dostępne aktualizacje pakietów
clean usuwa dane z pamięci podręcznej
If i put man dnf
I will get man page for dnf not found dnf
