Edit 2019-11-01 23:00 UTC: These have been moved to Rolling main/release and Rock main/updates repos. They should now upgrade as part of normal upgrade.
Installation guide:
Rock x86_64:
$ sudo dnf install --enablerepo rock-testing-x86_64 cpupower x86_energy_perf_policy kernel-release-desktop
Rolling x86_64:
$ sudo dnf install --enablerepo rolling-testing-x86_64 cpupower x86_energy_perf_policy kernel-release-desktop
If you need kernel devel package the add these to command string:
kernel-release-desktop-devel kernel-release-headers
Example of installation in progress in Rock x86_64 system:
Then rebooted in to same Rock system with working kernel 5.3.7:
Worth noting for Rock user that from kernel 5.1.21 to 5.3.7 there have been a ton of security fixes in addition to the mentioned hardware recognition fix mentioned above. This is not insignificant.
