Libreoffice seems not recognize keyboard. It seems to use international keyboard.
After installing packages libreoffice-language-support, libreoffice, and libreoffice-base, libreoffice writer refuses to open a new file and requires a JRE installationā¦
To be fair Iām not well versed in these matters as a US English speaker. Nor am I an expert with LibreOffice.
Is everything set like you want it in Options>Language Settings? That looks like where you would set that.
When you say libreoffice-language-support what do you mean the libreoffice-l10n-xx package for your language. (Which as I remember might be libreoffice-l10n-pt_BR? Apologies if I remember incorrectly.)
Post-edit: Donāt know if this helps but in Tools>Options/Language Settings>Languages there is a setting for āEnhanced Language Supportā āIgnore system input languageā. Donāt if that does/does not affect keyboard.
This one is more of reach or a guess.
One other possibility might be if you have libreoffice-kde5 package installed that might be interfering with something so you could try removing it and see if it helps. If not simply reinstall it. libreoffice-kde5 is a ālook and feelā package only to make LO look more Qt/KDE instead of GTK so it should not at all affect functionality of LO applications.
I have locale packages installed and libreoffice is properly translated. I have libreoffice-kde5 installed also and this made libreoffice menu more readable (without it letters was too small). The point is that the keyboard seems to be set as Us or international and characters like Ƨ are not where they are supposed to be ⦠Now, after installing libreoffice-base and libreoffice-extension-languagetool-6.2.0-1.x86_64, I have this JRE problem ⦠I guesss Iād better file a bug on it ā¦
In fact, characters like Ć£, Ć”, Ć¢ are the ones that I canāt reproduce at libreoffice. No problem with āƧā.
Also, the JRE problem arises if I install
Iāve removed it and JRE is no longer demanded.
And, reinstalling libreoffice and libreoffice-base did not help.
Yes, after removing this package, characters like Ć” are back again.
Unfortunately this backs the small letters menuā¦
Filed bug 2416 on this.
