As I understand it: Konsole does not close when there is an active process running in Konsole. Both of your examples fit that scenario. You can close Konsole but if you do the process will remain running in the background and then when you logout or reboot there might be a delay while the system scratches it’s head and figures out how to close the unexpected running process. In both cases you should see a dialog window like the one in my screen shot telling you to quit the running process or if you really want you can close the window.
I notice you have a pop dialog box warning you of a running process.
I have no such beast on my system.
clean install of OpenMandrivaLx.4.1-plasma.znver1.iso
but as you may notice from my other post…I may have an issue.
BTW I always check the hash value before writing to usb stick and I use blkid to check my target…and then I used from memory
as I have 2 internal drives…its a tower.
Then something is wrong. You definitely should have that dialog window. But let’s keep the conversation it the other thread for now. (Don’t want to put negative vibes on anyone’s coffee break!)
