Hi everyone.
Until this evening I have always been able to access my Moto X Android smart phones (designated as XT 1058 and XT 1060 respectively) via USB cable and Dolphin, no problem. After the recommended push update of two files this evening, Dolphin either does not show them as listed under Devices at all, or if it does, I select them and get something like:
“The file or folder udi=/org/kde/solid/udev/sys/devices/pci0000:000000:12.2/usb5/5-3 does not exist.”
(This was a verbatim response to the XT 1060), after which, the device listing for the XT 1060 permanently disappeared from the Dolphin device menu list entirely.
If I unplug and re-plug the USB cable, and attempt to open the XT 1060 with the File Manager through the Device Notifier pop-up screen, I get the same error message prefaced by a heading that identifies this as a KIO client error;
“Error - KIO Client <2>”
I noticed that the error message text string shown above also appears above the Dolphin window as a chain of subdirectories, and they are preceded initially by “mtp:”; in other words, the above message appears separately in a pop-up error message box when I try to invoke Dolphin via the Device Notifier; appearing above the Dolphin file list box is the following text string:
“mtp: > org > kde > solid > udev > sys > devices > pci0000:00 > 0000:00:12.2 > usb5 > 5-3”
(quotes mine)
If I go into my phone settings, and change the connection from a multimedia interface to a camera interface, I can open, view, and download the phone’s photo repertoire with Gwenview, etc., and that all seems to work properly.
I’ve tried warm and cold rebooting, and restarted the phones, there is no difference.
Any thoughts?
OM Lx 3.03
x86_64
running on hardware (not virtualbox)
KDE
Plasma
journalctl::
pr 10 15:38:07 michael-pc upowerd[3610]: unhandled action ‘bind’ on /sys/devices/pci0000:00/0000:00:12.2/usb5/5-3
Apr 10 15:38:07 michael-pc k3b[13931]: UdevQt: unhandled device action “bind”
Apr 10 15:38:07 michael-pc plasmashell[4699]: UdevQt: unhandled device action “bind”
Apr 10 15:40:55 michael-pc dolphin[20420]: Shortcut for action “open_in_KLook” “Preview” set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Apr 10 15:40:55 michael-pc dolphin[20420]: QObject::connect: No such slot DolphinMainWindow::focusChanged(QWidget*,QWidget*)
Apr 10 15:40:55 michael-pc dolphin[20420]: QObject::connect: (receiver name: ‘Dolphin#1’)
Apr 10 15:40:55 michael-pc dolphin[20420]: Trying to convert empty KLocalizedString to QString.
Apr 10 15:40:56 michael-pc dolphin[20420]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/today”)
Apr 10 15:40:56 michael-pc dolphin[20420]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/yesterday”)
Apr 10 15:40:56 michael-pc dolphin[20420]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/thismonth”)
Apr 10 15:40:56 michael-pc dolphin[20420]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/lastmonth”)
Apr 10 15:40:56 michael-pc dolphin[20420]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/documents”)
Apr 10 15:40:56 michael-pc dolphin[20420]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/images”)
Apr 10 15:40:56 michael-pc dolphin[20420]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/audio”)
Apr 10 15:40:56 michael-pc dolphin[20420]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/videos”)
Apr 10 15:40:56 michael-pc dolphin[20420]: Cannot creat accessible child interface for object: PlacesView(0x2ab26e0) index: 22
Apr 10 15:41:06 michael-pc dolphin[20420]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 15:41:37 michael-pc dolphin[20420]: QObject::connect: invalid null parameter
Apr 10 15:41:37 michael-pc baloo_file[4696]: QObject::connect: invalid null parameter
Apr 10 15:41:37 michael-pc kdeinit5[4652]: QObject::connect: invalid null parameter
Apr 10 15:41:50 michael-pc k3b[20453]: QFileInfo::absolutePath: Constructed with empty filename
Apr 10 15:41:52 michael-pc plasmashell[4699]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:143: TypeError: Cannot read property ‘Removable’ of undefined
Apr 10 15:41:53 michael-pc k3b[20453]: QObject::connect: No such signal KLineEdit::lostFocus()
Apr 10 15:42:19 michael-pc dolphin[20420]: QFileSystemWatcher::removePaths: list is empty
Apr 10 15:42:38 michael-pc dolphin[20538]: Shortcut for action “open_in_KLook” “Preview” set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Apr 10 15:42:38 michael-pc dolphin[20538]: QObject::connect: No such slot DolphinMainWindow::focusChanged(QWidget*,QWidget*)
Apr 10 15:42:38 michael-pc dolphin[20538]: QObject::connect: (receiver name: ‘Dolphin#1’)
Apr 10 15:42:38 michael-pc dolphin[20538]: Trying to convert empty KLocalizedString to QString.
Apr 10 15:42:38 michael-pc dolphin[20538]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/today”)
Apr 10 15:42:38 michael-pc dolphin[20538]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/yesterday”)
Apr 10 15:42:38 michael-pc dolphin[20538]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/thismonth”)
Apr 10 15:42:38 michael-pc dolphin[20538]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/lastmonth”)
Apr 10 15:42:38 michael-pc dolphin[20538]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/documents”)
Apr 10 15:42:38 michael-pc dolphin[20538]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/images”)
Apr 10 15:42:38 michael-pc dolphin[20538]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/audio”)
Apr 10 15:42:38 michael-pc dolphin[20538]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/videos”)
Apr 10 15:42:38 michael-pc dolphin[20538]: Cannot creat accessible child interface for object: PlacesView(0x2454640) index: 22
Apr 10 15:44:33 michael-pc dolphin[20538]: QFileSystemWatcher::removePaths: list is empty
Apr 10 15:45:58 michael-pc kernel: LoadPin: kernel-module old-api-pinning-ignored obj= pid=20612 cmdline="/sbin/modprobe -q – nls_utf8"
Apr 10 15:45:59 michael-pc dolphin[20623]: Shortcut for action “open_in_KLook” “Preview” set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Apr 10 15:45:59 michael-pc dolphin[20623]: QObject::connect: No such slot DolphinMainWindow::focusChanged(QWidget*,QWidget*)
Apr 10 15:45:59 michael-pc dolphin[20623]: QObject::connect: (receiver name: ‘Dolphin#1’)
Apr 10 15:45:59 michael-pc dolphin[20623]: Trying to convert empty KLocalizedString to QString.
Apr 10 15:45:59 michael-pc dolphin[20623]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/today”)
Apr 10 15:45:59 michael-pc dolphin[20623]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/yesterday”)
Apr 10 15:45:59 michael-pc dolphin[20623]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/thismonth”)
Apr 10 15:45:59 michael-pc dolphin[20623]: org.kde.dolphin: Ignore KIO url: QUrl(“timeline:/lastmonth”)
Apr 10 15:45:59 michael-pc dolphin[20623]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/documents”)
Apr 10 15:45:59 michael-pc dolphin[20623]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/images”)
Apr 10 15:45:59 michael-pc dolphin[20623]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/audio”)
Apr 10 15:45:59 michael-pc dolphin[20623]: org.kde.dolphin: Ignore KIO url: QUrl(“search:/videos”)
Apr 10 15:45:59 michael-pc dolphin[20623]: Cannot creat accessible child interface for object: PlacesView(0x1b148c0) index: 23
Apr 10 15:46:11 michael-pc dolphin[20623]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 15:46:12 michael-pc dolphin[20623]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 15:46:13 michael-pc dolphin[20623]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 15:46:14 michael-pc dolphin[20623]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 15:46:15 michael-pc dolphin[20623]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 15:46:16 michael-pc dolphin[20623]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 15:46:21 michael-pc dolphin[20623]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 15:46:22 michael-pc dolphin[20623]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 15:46:36 michael-pc dolphin[20623]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 15:46:43 michael-pc dolphin[20623]: QProcess: Destroyed while process ("/usr/bin/baloo_filemetadata_temp_extractor") is still running.
Apr 10 16:24:36 michael-pc kernel: usb 5-3: USB disconnect, device number 5
Apr 10 16:24:36 michael-pc kdeinit5[4652]: UdevQt: unhandled device action “unbind”
Apr 10 16:24:36 michael-pc org_kde_powerdevil[4744]: UdevQt: unhandled device action “unbind”
Apr 10 16:24:36 michael-pc dolphin[20623]: UdevQt: unhandled device action “unbind”
Apr 10 16:24:36 michael-pc upowerd[3610]: unhandled action ‘unbind’ on /sys/devices/pci0000:00/0000:00:12.2/usb5/5-3
Apr 10 16:24:36 michael-pc plasmashell[4699]: UdevQt: unhandled device action “unbind”
Apr 10 16:24:36 michael-pc baloo_file[4696]: UdevQt: unhandled device action “unbind”
Apr 10 16:28:30 michael-pc plasmashell[4699]: QXcbConnection: XCB error: 2 (BadValue), sequence: 29980, resource id: 100663301, major code: 143 (Unknown), minor code: 3
Apr 10 16:28:37 michael-pc plasmashell[4699]: QXcbConnection: XCB error: 2 (BadValue), sequence: 29997, resource id: 79691783, major code: 143 (Unknown), minor code: 3
Apr 10 16:39:49 michael-pc kscreenlocker_greet[21582]: kf5.kpackage: No metadata file in the package, expected it at: “/usr/share/wallpapers/Next/contents/images/”
Apr 10 16:39:49 michael-pc kscreenlocker_greet[21582]: WARNING: Cannot find style “org.kde.desktop” - fallback: “/usr/lib64/qt5/qml/QtQuick/Controls/Styles/Base”
Apr 10 16:39:49 michael-pc kscreenlocker_greet[21582]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Apr 10 16:39:49 michael-pc kscreenlocker_greet[21582]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:20:1: module “QtQuick.VirtualKeyboard” is not installed
Apr 10 17:01:01 michael-pc CROND[21708]: (root) CMD (nice -n 19 run-parts --report /etc/cron.hourly)
Apr 10 17:20:57 michael-pc smartd[3607]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 176 to 171
Apr 10 17:21:09 michael-pc smartd[3607]: Device: /dev/sdc [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 111 to 110
Apr 10 17:21:52 michael-pc freshclam[3596]: Received signal: wake up
Apr 10 17:21:52 michael-pc freshclam[3596]: ClamAV update process started at Tue Apr 10 17:21:52 2018
Apr 10 17:21:52 michael-pc freshclam[3596]: WARNING: Your ClamAV installation is OUTDATED!
Apr 10 17:21:52 michael-pc freshclam[3596]: WARNING: Local version: 0.99.2 Recommended version: 0.100.0
Apr 10 17:21:52 michael-pc freshclam[3596]: DON’T PANIC! Read http://www.clamav.net/documents/upgrading-clamav
Apr 10 17:21:52 michael-pc freshclam[3596]: main.cvd is up to date (version: 58, sigs: 4566249, f-level: 60, builder: sigmgr)
Apr 10 17:21:52 michael-pc freshclam[3596]: daily.cld is up to date (version: 24468, sigs: 1905629, f-level: 63, builder: neo)
Apr 10 17:21:52 michael-pc freshclam[3596]: bytecode.cvd is up to date (version: 319, sigs: 75, f-level: 63, builder: neo)
Apr 10 17:21:55 michael-pc PackageKit[4994]: uid 1001 is trying to obtain org.freedesktop.packagekit.system-sources-refresh auth (only_trusted:0)
Apr 10 17:21:55 michael-pc PackageKit[4994]: uid 1001 obtained auth for org.freedesktop.packagekit.system-sources-refresh
Apr 10 17:22:11 michael-pc PackageKit[4994]: refresh-cache transaction /195_bccaeacd from uid 1001 finished with success after 15721ms
Apr 10 17:22:14 michael-pc PackageKit[4994]: get-updates transaction /196_eebabeec from uid 1001 finished with success after 2582ms
Apr 10 17:22:14 michael-pc PackageKit[4994]: get-updates transaction /197_cbeadded from uid 1001 finished with success after 538ms
Apr 10 17:37:07 michael-pc systemd[1]: Starting Cleanup of Temporary Directories…
Apr 10 17:37:07 michael-pc systemd-tmpfiles[21896]: [/usr/lib/tmpfiles.d/var.conf:17] Duplicate line for path “/var/log/lastlog”, ignoring.
Apr 10 17:37:08 michael-pc systemd[1]: Started Cleanup of Temporary Directories.
Apr 10 17:38:53 michael-pc kernel: usb 5-3: new high-speed USB device number 6 using ehci-pci
Apr 10 17:38:53 michael-pc kernel: usb 5-3: New USB device found, idVendor=22b8, idProduct=2e62
Apr 10 17:38:53 michael-pc kernel: usb 5-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Apr 10 17:38:53 michael-pc kernel: usb 5-3: Product: XT1060
Apr 10 17:38:53 michael-pc kernel: usb 5-3: Manufacturer: motorola
Apr 10 17:38:53 michael-pc kernel: usb 5-3: SerialNumber: T062005TUG
Apr 10 17:38:54 michael-pc baloo_file[4696]: QObject::connect: invalid null parameter
Apr 10 17:38:54 michael-pc org_kde_powerdevil[4744]: UdevQt: unhandled device action “bind”
Apr 10 17:38:54 michael-pc baloo_file[4696]: UdevQt: unhandled device action “bind”
Apr 10 17:38:54 michael-pc upowerd[3610]: unhandled action ‘bind’ on /sys/devices/pci0000:00/0000:00:12.2/usb5/5-3
Apr 10 17:38:54 michael-pc dolphin[20623]: QObject::connect: invalid null parameter
Apr 10 17:38:54 michael-pc dolphin[20623]: UdevQt: unhandled device action “bind”
lines 69873-69906
lines 69873-69906
[michael@michael-pc ~]$ inxi -F -c 0
System: Host: michael-pc Kernel: 4.15.12-desktop-1omv x86_64 (64 bit) Desktop: KDE Plasma 5.10.5
Distro: OpenMandrivaLinux 3.0 Einsteinium
Machine: Mobo: MSI model: A88XM-E45 V2 (MS-7721) v: 5.0 Bios: American Megatrends v: V5.3 date: 04/07/2016
CPU: Quad core AMD A10-7890K Radeon R7 12 Compute Cores 4C+8G (-MCP-) cache: 8192 KB
clock speeds: max: 4100 MHz 1: 1699 MHz 2: 1698 MHz 3: 1698 MHz 4: 1699 MHz
Graphics: Card-1: Advanced Micro Devices [AMD/ATI] Kaveri [Radeon R7 Graphics]
Card-2: NVIDIA GF108 [GeForce GT 730]
Display Server: OpenMandriva X.org 119.6 driver: nvidia Resolution: 1920x1080@60.00hz
GLX Renderer: GeForce GT 730/PCIe/SSE2 GLX Version: 4.6.0 NVIDIA 390.25
Audio: Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller driver: snd_hda_intel
Card-2 NVIDIA GF108 High Definition Audio Controller driver: snd_hda_intel
Card-3 Advanced Micro Devices [AMD/ATI] Kaveri HDMI/DP Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.15.12-desktop-1omv
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: 4c:cc:6a:46:a4:c9
Drives: HDD Total Size: 10002.0GB (2.8% used) ID-1: /dev/sda model: HGST_HDN724030AL size: 3000.6GB
ID-2: /dev/sdb model: HGST_HDN724030AL size: 3000.6GB
ID-3: /dev/sdc model: WDC_WD20EZRX size: 2000.4GB
ID-4: /dev/sdd model: WDC_WD20EZRX size: 2000.4GB
Partition: ID-1: / size: 1.8T used: 17G (1%) fs: ext4 dev: /dev/sdd2
ID-2: swap-1 size: 4.19GB used: 0.00GB (0%) fs: swap dev: /dev/sdb1
ID-3: swap-2 size: 4.19GB used: 0.00GB (0%) fs: swap dev: /dev/sdc6
ID-4: swap-3 size: 9.45GB used: 0.00GB (0%) fs: swap dev: /dev/sdd3
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 14.2C mobo: N/A gpu: 63C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 197 Uptime: 2:25 Memory: 2296.7/6990.0MB Client: Shell (bash) inxi: 2.2.27
