I have [Searched] the forum for my issue and found nothing related or helpful
I have checked the [Resources category ]([Resources Index])
I have reviewed the [Wiki] for relevant information
I have read the the [Release Notes and Errata]
Rome latest kernel
KDE plasma 6 Wayland
Kernel 6.15 does not boot and checking logs to my untrained eyes could not uncover anything.
After updating with the built in update feature the latest kernel causes the system to crash, blinking the caps lock key. I have tried uninstalling and installing the kernel and updating grub2. This is the extent of the things I have tried besides the obvious of trying to run the commands the updater runs as per the wiki page.
Which logs should I look in and/or post? I followed many kernel panic threads but none of them have posted logs relevant to my issues. The logs indicate the system stops responding before it can post an error.
Using an intel evo with built in intel arc graphics. Booting off a USB ssd drive. on an MSI prestige 16 AI evo B1MG
Booting old kernel works fine. I looked for other kernels in the repos that were 6.15 but there is only one from what I saw.
Thanks for any help. It’s been 10 years it feels like since I’ve had to post in a forum, usually I can figure it out from other posts.
Sucsessful and unsucsessful boot respectively:
-- Boot ef21ba8e91cb430fa7b10cc449b64c5d --
May 12 05:37:09 kernel: CPU topo: Boot CPU APIC ID not the first enumerated APIC ID: 20 != 10
May 12 05:37:09 kernel: CPU topo: [Firmware Bug]: APIC enumeration order not specification compliant
May 12 05:37:09 kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
May 12 05:37:09 kernel: #2 #4 #5 #7 #9 #11
May 12 05:37:09 kernel: pnp 00:03: disabling [mem 0x00000000-0x00000fff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
May 12 05:37:09 kernel: hpet_acpi_add: no address or irqs in _CRS
May 12 05:37:09 kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
May 12 05:37:09 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
May 12 05:37:10 kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WQAK data block query control method not found
May 12 05:37:10 kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WQAL data block query control method not found
May 12 05:37:10 kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WMAJ method block execution control method not found
May 12 05:37:10 kernel: pci 10000:e0:06.2: Primary bus is hard wired to 0
May 12 05:37:11 kernel: pci 10000:e1:00.0: can't override BIOS ASPM; OS doesn't have ASPM control
May 12 05:37:11 kernel: pcieport 10000:e0:06.2: can't derive routing for PCI INT C
May 12 05:37:11 kernel: pcieport 10000:e0:06.2: PCI INT C: no GSI
May 12 05:37:11 kernel: pcieport 10000:e0:06.2: can't derive routing for PCI INT A
May 12 05:37:11 kernel: nvme 10000:e1:00.0: PCI INT A: no GSI
-- Boot fab80a9cea9c41fd8fa8684d29a1ed24 --
May 12 05:39:00 kernel: CPU topo: Boot CPU APIC ID not the first enumerated APIC ID: 20 != 10
May 12 05:39:00 kernel: CPU topo: [Firmware Bug]: APIC enumeration order not specification compliant
May 12 05:39:00 kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
May 12 05:39:00 kernel: #2 #4 #5 #7 #9 #11
May 12 05:39:00 kernel: pnp 00:03: disabling [mem 0x00000000-0x00000fff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
May 12 05:39:00 kernel: hpet_acpi_add: no address or irqs in _CRS
May 12 05:39:00 kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
May 12 05:39:00 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
May 12 05:39:01 kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WQAK data block query control method not found
May 12 05:39:01 kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WQAL data block query control method not found
May 12 05:39:01 kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WMAJ method block execution control method not found
May 12 05:39:01 kernel: pci 10000:e0:06.2: Primary bus is hard wired to 0
May 12 05:39:02 kernel: pci 10000:e1:00.0: can't override BIOS ASPM; OS doesn't have ASPM control
May 12 05:39:02 kernel: pcieport 10000:e0:06.2: can't derive routing for PCI INT C
May 12 05:39:02 kernel: pcieport 10000:e0:06.2: PCI INT C: no GSI
May 12 05:39:02 kernel: pcieport 10000:e0:06.2: can't derive routing for PCI INT A
May 12 05:39:02 kernel: nvme 10000:e1:00.0: PCI INT A: no GSI
May 12 05:39:06 systemd-journald[708]: File /var/log/journal/9794c032fb424b1fb580ab91cfa70fe0/system.journal corrupted or uncleanly shut down, renaming and replacing.
May 12 05:39:07 kernel: resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcffff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
May 12 05:39:07 kernel: caller igen6_probe+0x199/0xb00 [igen6_edac] mapping multiple BARs
May 12 05:39:07 kernel: intel_pmc_core INT33A1:00: Assuming a default substate order for this platform
May 12 05:39:08 kernel: FAT-fs (sda1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
May 12 05:39:08 kernel: msi_ec: Firmware version is not supported: '15A1EMS1.109'
May 12 05:39:08 kernel: spi-nor spi0.0: supply vcc not found, using dummy regulator
May 12 05:39:08 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
May 12 05:39:08 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
May 12 05:39:10 kernel: Bluetooth: hci0: Failed to read codec capabilities (-95)
May 12 05:39:15 (uetoothd)[931]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
May 12 05:39:15 kernel: nvme nvme0: using unchecked data buffer
May 12 05:39:16 kernel: Bluetooth: hci0: Failed to read codec capabilities (-95)
May 12 05:39:17 dbus-broker-launch[927]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
May 12 05:39:18 dbus-broker-launch[927]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
May 12 05:39:18 systemd-xdg-autostart-generator[1035]: Configuration file /home/dillon/.config/autostart/draketray.desktop is marked executable. Please remove executable permission bits>
May 12 05:39:18 dbus-broker-launch[1040]: Service file '/usr/share//dbus-1/services/obex-client.service' is not named after the D-Bus name 'org.bluez.obex.client'.
May 12 05:39:18 dbus-broker-launch[1040]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1>
May 12 05:39:18 dbus-broker-launch[1040]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
May 12 05:39:18 dbus-broker-launch[1040]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notification>
May 12 05:39:19 systemd-xdg-autostart-generator[1112]: Configuration file /home/dillon/.config/autostart/draketray.desktop is marked executable. Please remove executable permission bits>
May 12 05:39:21 xdg-desktop-por[1131]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
May 12 05:39:21 kernel: block nvme0n1: No UUID available providing old NGUID
May 12 05:39:21 wireplumber[1049]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
May 12 05:39:22 baloo_file[1123]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.28'
May 12 05:39:22 baloo_file[1123]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.30'
May 12 05:39:24 wireplumber[1049]: s-monitors-utils: skipping device libcamera:\_SB_.PC00.XHCI.RHUB.HS05-5:1.0-5986:1193
May 12 05:39:24 wireplumber[1049]: s-monitors-utils: skipping device libcamera:\_SB_.PC00.XHCI.RHUB.HS05-5:1.2-5986:1193
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 124 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 124 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 146 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 146 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 33 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 33 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 220 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 220 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 219 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 219 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 209 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 209 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 217 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 217 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 215 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 215 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 223 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 223 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 213 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 213 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 221 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 221 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 211 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 211 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 218 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 218 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 216 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 216 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 224 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 224 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 214 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 214 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 222 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 222 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 212 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 212 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 164 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 164 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 122 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 122 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 32 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 32 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 202 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 202 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 136 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 136 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 144 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 144 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 134 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 134 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 142 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 142 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 132 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 132 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 140 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 140 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 130 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 130 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 139 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 139 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 129 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 129 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 137 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 137 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 127 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 127 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 145 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 145 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 135 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 135 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 143 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 143 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 133 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 133 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 141 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 141 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 131 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 131 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 138 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 138 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 128 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 128 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 123 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 123 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 165 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 165 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 174 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 174 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 182 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 182 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 172 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 172 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 180 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 180 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 170 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 170 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 179 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 179 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 169 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 169 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 177 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 177 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 167 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 167 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 175 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 175 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 183 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 183 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 173 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 173 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 181 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 181 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 171 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 171 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 178 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 178 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 168 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 168 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 176 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 176 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 166 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 166 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 155 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 155 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 18 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 18 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 125 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 125 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 187 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 187 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 186 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 186 affinity is now unmanaged
May 12 05:39:25 irqbalance[933]: Cannot change IRQ 208 affinity: Read-only file system
May 12 05:39:25 irqbalance[933]: IRQ 208 affinity is now unmanaged
May 12 05:39:29 kded6[1254]: QDBusObjectPath: invalid path "/modules/oom-notifier"
May 12 05:39:29 kded6[1254]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
May 12 05:39:29 kactivitymanagerd[1304]: kf.windowsystem: virtual void KX11Extras::connectNotify(const QMetaMethod &) may only be used on X11
May 12 05:39:29 plasmashell[1271]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutA>
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
May 12 05:39:30 kded6[1254]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
May 12 05:39:30 kded6[1254]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
May 12 05:39:30 kded6[1254]: QDBusObjectPath: invalid path "/modules/wpad-detector"
May 12 05:39:30 kded6[1254]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
May 12 05:39:30 plasmashell[1271]: Toolbox not loading, toolbox package is either invalid or disabled.
May 12 05:39:30 kconf_update[1383]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
May 12 05:39:30 kconf_update[1383]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
May 12 05:39:30 kconf_update[1383]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
May 12 05:39:30 kconf_update[1383]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
May 12 05:39:30 dbus-broker-launch[927]: Activation request for 'org.freedesktop.ModemManager1' failed: The systemd unit 'dbus-org.freedesktop.ModemManager1.service' could not be found.
May 12 05:39:30 kded6[1254]: kf.modemmanagerqt: Failed enumerating MM objects: "org.freedesktop.DBus.Error.NameHasNoOwner"
"Could not activate remote peer 'org.freedesktop.ModemManager1': activation request failed: unknown unit"
May 12 05:39:30 bluetoothd[931]: /builddir/build/BUILD/bluez-5.82-build/bluez-5.82/src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon pow>
May 12 05:39:30 kded6[1254]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.stereo-fallback.monitor"
May 12 05:39:31 org_kde_powerdevil[1317]: org.kde.powerdevil: [DDCutilDetector]: Failed to initialize callback
May 12 05:39:31 org_kde_powerdevil[1317]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this ha>
May 12 05:39:31 org_kde_powerdevil[1317]: org.kde.powerdevil: Handle button events action could not check for screen configuration
May 12 05:39:32 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
May 12 05:39:32 kdeconnectd[1467]: 2025-05-12T05:39:32 default: Error sending UDP packet: QAbstractSocket::NetworkError
May 12 05:39:32 kdeconnectd[1467]: 2025-05-12T05:39:32 kdeconnect.core: Failed to open any MDNS client sockets
May 12 05:39:32 kdeconnectd[1467]: 2025-05-12T05:39:32 kdeconnect.core: Failed to open any MDNS server sockets
May 12 05:39:32 kdeconnectd[1467]: 2025-05-12T05:39:32 qt.bluetooth.bluez: Bluetooth device is powered off
May 12 05:39:32 kdeconnectd[1530]: QThreadStorage: entry 8 destroyed before end of thread 0x55a497235a20
May 12 05:39:32 kdeconnectd[1530]: QThreadStorage: entry 3 destroyed before end of thread 0x55a497235a20
May 12 05:39:32 kdeconnectd[1530]: QThreadStorage: entry 2 destroyed before end of thread 0x55a497235a20
May 12 05:39:33 xdg-desktop-por[1131]: Choosing gtk.portal for org.freedesktop.impl.portal.Wallpaper as a last-resort fallback
May 12 05:39:37 plasmashell[1271]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
May 12 05:39:37 plasmashell[1271]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.stereo-fallback.monitor"
May 12 05:39:42 kwalletd6[1672]: Application "Chromium" using kwallet without parent window!
May 12 05:39:57 kwin_wayland[1121]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 12 05:40:04 plasmashell[1271]: kf.windowsystem: static void KX11Extras::forceActiveWindow(WId, long) may only be used on X11
May 12 05:40:06 plasmashell[1271]: kf.windowsystem: static void KX11Extras::forceActiveWindow(WId, long) may only be used on X11
May 12 05:40:24 baloorunner[1946]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
May 12 05:40:24 baloorunner[1946]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
May 12 05:40:24 konsole[1957]: QLayout: Cannot add a null widget to QHBoxLayout/
May 12 05:41:38 kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=5661 end=5662) time 271 us, min 2385, max 2399, scanline start 2372, end 2374
May 12 05:43:51 kwin_wayland[1121]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 12 05:44:09 kdeconnectd[1467]: 2025-05-12T05:44:09 kdeconnect.core: Failed to send mDNS query: Cannot assign requested address
May 12 05:44:10 plasmashell[1271]: qrc:/qt/qml/org/kde/plasma/components/ScrollView.qml:53:29: QML ScrollBar: Binding loop detected for property "visible":
qrc:/qt/qml/org/kde/plasma/components/ScrollBar.qml:24:5
May 12 05:44:11 systemd-coredump[2332]: [🡕] Process 2313 (chrome) of user 1001 dumped core.
Stack trace of thread 1:
#0 0x00007ff9049fb262 __mmap (libc.so.6 + 0x10d262)
#1 0x00007ff9049317b3 getrandom_vdso (libc.so.6 + 0x437b3)
#2 0x00007ff905ffc316 startParsing (libexpat.so.1 + 0x2c316)
#3 0x00007ff906001caf XML_ParseBuffer (libexpat.so.1 + 0x31caf)
#4 0x00007ff906182208 FcConfigParseAndLoadFromMemoryInternal (libfontconfig.so.1 + 0x58208)
#5 0x00007ff90616a318 FcInitLoadOwnConfig (libfontconfig.so.1 + 0x40318)
#6 0x00007ff90616a4fe FcInitLoadConfigAndFonts (libfontconfig.so.1 + 0x404fe)
#7 0x00007ff90616a651 FcInit (libfontconfig.so.1 + 0x40651)
#8 0x00005563b3454c32 _ZN4base12NoDestructorIN3gfx12_GLOBAL__N_116GlobalFontConfigEEC2IJEEEDpOT_ (/usr/lib64/chromium/chrome + 0x7f63c32)
ELF object binary architecture: AMD x86-64
May 12 05:44:11 drkonqi-coredump-launcher[2345]: Unable to find file for pid 2313 expected at "kcrash-metadata/chrome.fab80a9cea9c41fd8fa8684d29a1ed24.2313.ini"
May 12 05:44:11 drkonqi-coredump-launcher[2344]: Unable to find file for pid 2313 expected at "kcrash-metadata/chrome.fab80a9cea9c41fd8fa8684d29a1ed24.2313.ini"
May 12 05:44:11 drkonqi-coredump-launcher[2345]: Nothing handled the dump :O
May 12 05:44:11 drkonqi-coredump-launcher[2344]: Nothing handled the dump :O
May 12 05:46:04 (pcscd)[2636]: pcscd.service: Referenced but unset environment variable evaluates to an empty string: PCSCD_ARGS
May 12 05:46:55 irqbalance[933]: Cannot change IRQ 210 affinity: Read-only file system
May 12 05:46:55 irqbalance[933]: IRQ 210 affinity is now unmanaged
