The application close iself when tying to open or create a database.
When i launch it from Konsole i get the following message : “Instruction not permitted”.
Tried argument --debug-info noticed it use libgcrypt, installed that package but it didn’t change anything.
Do i miss anything to make it work ?
So for further testing I fired up an ancient ASUS notebook with a i5 3337u cpu and Rolling installed. Installed keepasscx and when I ran it and tried to create a database I also got the illegal instruction error that @Rick399 was getting. We talked to @bero on IRC and he told us that this could be an an instruction that older hardware can not handle. We sometimes miss things like this because most computers in daily use in contributor group tend to be relatively newer.
Anyway @bero was able to find a fix for this and build a new version of the package argon2. When you upgrade your system you should see lib64argon2_1-20190702-4 and this should fix the illegal instruction error in keepassxc.
Those qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow) errors are in every journal log I have seen. OM devs tell me they are nothing to be concerned about.
