Keditbookmarks: Segmentation fault (core dumped)
OpenMandriva version:
OMLx Rock 6.0 znver1
KDE
There’s a rumor that KDE/Dolphin can use “bookmarks” in addition to “places”. And indeed you can create bookmarks (and they work as you would expect). You can add bookmarks to the toolbar and they can be accessed through the “Go” menu.
They are stored here: ~/.local/share/dolphin
The problem is you can’t edit them without going directly into the xml file. HOWEVER there is a program that you can install (plasma6-keditbookmarks) that is supposed to install the editor.
It does and you now have an “Edit Bookmarks” entry in the dolphin “Go” menu. But it doesn’t work. When you run it directly from the CLI you get:
$ keditbookmarks
So near as I can tell the only dependency is: lib64kbookmarkmodel_private6
I’ve installed and uninstalled a couple times and still nothing. Anyone else play around with this? It looks like a useful feature.
Probably needs rebuilt. It might have been missed. Plus, all of the plasma6 prefixed packages are supposed be replaced. They only existed to migrate away from Plasma 5.
I figured it’s something like that. Like I said in the chat - no rush.
I know how to edit an xml file :wink:
Looks like this is fixed in Cooker
You sure? :wink:
