Ladies and Gentlemen,
I couldn’t start KDESVN from the menu but it I succeeded launching it from the command line.
Not sure what it means (warnings / errors ?) below is the the output of the terminal ![]()
[pierre@caladan ~]$ kdesvn
QCommandLineParser: already having an option named "h"
QCommandLineParser: already having an option named "help-all"
QCommandLineParser: already having an option named "v"
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Your names" msgid_plural: "" msgctxt: "NAME OF TRANSLATORS"
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Your emails" msgid_plural: "" msgctxt: "EMAIL OF TRANSLATORS"
QSqlDatabase: QSQLITE driver not loaded
QSqlDatabase: available drivers:
Failed to open main database.
"kde-applications.menu" not found in ("/etc/xdg/menus")
KDE Plasma 6.5.5 KWin / (XLibre)
Mostly using GIT nowdays but I still use SVN sometimes
No hurry at all, I can work, would appreciate any input. ![]()
Cheers
