KDE no menu or plasmoids, endless disk activity & coredumps!
Rome 25.06
KDE X11
On first start/login there is sporadically no “Start” menu available, some Plasmoids show blank spaces, there is no VT available (CTRL-ALT-F1/2/3), the hard disk activity light is permanently on and the only thing I can do is a CTRL-ALT-BKSPACE which allows me to re-login.
After logging in and running the system log viewer and btop, I see continuous “kf.baloo: Extractor crashed” errors.
Snippet from syslog (had to pause it because it was constantly refreshing):
Kernel Log - https://pastebin.com/UWNrEtvD
Xorg Log - https://pastebin.com/ZcNTTFxY
Operating System: OpenMandriva ROME 25.06
KDE Plasma Version: 6.3.4
Qt Version: 6.9.0
Kernel Version: 6.14.2-desktop-3omv2590 (64-bit)
Graphics Platform: X11
Processors: 16 × AMD Ryzen 7 3700X 8-Core Processor
Memory: 31,3 GiB of RAM
Graphics Processor: AMD Radeon RX 6750 XT
Manufacturer: ASUS
I had this same problem back in March or April this year when I first tried OM but just put it down to a bad install or something. This is a relatively new install (3 weeks?) and everything was completely normal until today - then this weird stuff happened.
Anyone else experience this? I did find another thread which was sort of on this theme but it turned out it was the Nouveau driver, and I’m using Radeon.
Regards,
Kev.
Re-seat your ram and turn off XMP(those CPU’s were quite finicky back then). If that doesn’t help boot from a live usb and check disk health.
Agreed. That many problems means it’s typically hardware related.
can you disable baloo indexing ?
