Versione nzver1.
Ho provato a scorrere i programmi nel menù e mi sono fermato al terzo: kalk non funziona (kcalc funziona, ma vorrei sapere com’è questo)
QmlApplicationEngine failed to load component
qrc:/qml/main.qml:12:1: module "org.kde.kirigami" is not installed
qrc:/qml/main.qml:11:1: module "Qt.labs.settings" is not installed
qrc:/qml/main.qml:10:1: module "Qt.labs.platform" is not installed
qrc:/qml/main.qml:9:1: module "QtQuick.Controls" is not installed
qrc:/qml/main.qml:8:1: module "QtQuick.Layouts" is not installed
Adesso continuo a scorrere il menù
Delaboratory
Fatal Error: Mismatch between the program and library build versions detected.
The library used 2.8 (no debug,Unicode,compiler with C++ ABI 1016,wx containers,compatible with 2.6),
and your program used 2.8 (no debug,Unicode,compiler with C++ ABI 1014,wx containers,compatible with 2.6).
Annullato (core dump creato)
Imagemagic (versione grafica). Crasha, ma da Konsole si chiude senza messaggi
