Currently I am running opemandriva 6.0,
I forked and modified the spec file for zim :
# fix bogs requires
%global __requires_exclude %{?__requires_exclude:%__requires_exclude|}^typelib\\(GtkosxApplication
Version: 0.76.3
Release: 4
Summary: A desktop wiki and outliner
Source: https : // www.zim-wiki.org/downloads/%{name}-%{version}.tar.gz
License: GPLv2
Group: Editors
Url: https://www.zim-wiki.org/
BuildRequires: pkgconfig(python)
BuildRequires: pkgconfig(pygobject-3.0)
BuildRequires: python3dist(pygobject)
BuildRequires: python3dist(setuptools)
BuildRequires: pkgconfig(gtk+-3.0)
BuildRequires: typelib(GObject)
BuildRequires: typelib(Gtk)
BuildRequires: typelib(Gdk)
BuildRequires: typelib(GdkPixbuf)
BuildRequires: typelib(Gio)
BuildRequires: typelib(GLib)
BuildRequires: typelib(Pango)
Requires: python
Requires: python-gobject3
Recommends: typelib(GtkSource)
Recommends: typelib(GtkSpell)
Suggests: pyxdg
Suggests: xdg-utils
BuildArch: noarch
%description
Zim is a WYSIWYG text editor written in Gtk2-Perl which aims to bring
the concept of a wiki to your desktop. Every page is saved as a text
file with wiki markup. Pages can contain links to other pages, and are
saved automatically. Creating a new page is as easy as linking to a
non-existing page. Pages are ordered in a hierarchical structure that
gives it the look and feel of an outliner. This tool is intended to
keep track of TODO lists or to serve as a personal scratch book.
%prep
%autosetup -p1 -n %{name}-%{version}
%build
python setup.py build
%install
python setup.py install --root=%{buildroot} --skip-build
#install icons
%__install -D -m 0644 data/zim.png %{buildroot}%{_icons64dir}/zim.png
%__install -D -m 0644 data/zim.png %{buildroot}%{_iconsdir}/hicolor/64x64/mimetypes/application-x-zim-notebook.png
%__install -D -m 0644 data/zim.png %{buildroot}%{_iconsdir}/hicolor/64x64/mimetypes/gnome-mime-application-x-zim-notebook.png
%find_lang %{name}
%clean
%files -f %{name}.lang
%{_bindir}/%{name}
%{_datadir}/%{name}/*
%{_datadir}/applications/org.zim_wiki.Zim.desktop
%{python_sitelib}/*
%{_mandir}/man1/%{name}*
#{_datadir}/pixmaps/%{name}.png
%{_datadir}/mime/*
%{_datadir}/metainfo/org.zim_wiki.Zim.appdata.xml
%{_iconsdir}/hicolor/*/*/*
%{_iconsdir}/ubuntu*/*/*/*
I installed the dependencies using the command :
sudo dnf builddep zim.spec
Now I am trying to build it usign the command:
rpmbuild -ba zim.spec
the problem now is the /usr/bin/zim created into the package looks like:
$ head /usr/bin/zim
#!python
# This script is a wrapper around zim.main.main() for running zim as
# an application.
import sys
import os
import re
to work properly the file have to start with
#!/usr/bin/python
Any Idea on how to fix this ?? can you suggest any resource I can read ?
Thanks in advance : )
