While I’ve fixed the problems I was having before by converting to “rolling” and getting a far more recent kernel, I’ve been trying to actually build a kernel myself just for a learning experience. But no matter which version I download, it just will not build on OpenMandriva at all. I really don’t understand why I’m still unable to build a kernel, since my LLVM/Clang version is now at version 11. I’ve tried to build kernel 5.10-rc7 and 5.10.1 and both fail with the same error:
SORTTAB vmlinux
inconsistent ORC unwind table entries in file: vmlinux
Failed to sort kernel tables
make: *** [Makefile:1170: vmlinux] Error 1
Which is exactly the same error I got with OpenMandriva Lx 4.1 I’ve tried changing the kernel config to the frame pointer unwinder and I get a different error, but it stills fails to build all the same. I’ve tried the link below adding the arguments listed within, and it still fails the same as if I just run “make” without any arguments.
https://www.kernel.org/doc/html/latest/kbuild/llvm.html
According to the link below, the kernel should be able to be built with Clang 9.0, and clearly OpenMandriva’s kernel has been built with LLVM/Clang. So it must be possible to do it.
https://unix.stackexchange.com/questions/544690/how-do-i-compile-the-linux-kernel-with-clang
How on earth do the OpenMandriva dev’s do it? Exactly how and what do they use to build the kernel for OpenMandriva? As I just don’t understand why it’s still failing to build.
James
