Installing Wine-staging on OM
  • _OpenMandriva Lx version:_Rome
Hi All,
Is there a way of installing wine-staging. I followed the winehq istructions for fedora (Added the fedora 40 winehq repo) on the off chance that would work but unsuprisingly hit some dependency issues. As far as I am aware even arch makes a distinction between the stable and staging branch so I assume the wine packaged in the repos is the latest stable version. I need it for some VST plugins to work and even the new 10.0 version doesn’t seem to do the trick. I have tested the same VSTs in mint and have no problem with staging installed so I am reasonably sure it is just a version problem. The VSTs that don’t work are the ones only available as 64bit so I imagine that that has something to do with it.
Many thanks
