I have checked the Resources category (Resources Index )
Hyprland (have KDE for fallback)
when i try to: sudo dnf install R i get a Transaction summary of 1116 Packages, most of which are texlive-* with its size being 800 after installation
i can post the transaction summary but i think it has no value.
R-devel is being pulled in as a dependency, which is then pulling in all of the texlive stuff. I couldn’t tell you why, but that is what is happening.
In cases like this, you need to look over what the upstream has for dependencies:
We also provide all the recipes we use to build the packages you use:
Requires: and BuildRequires: are going to provide the dependencies that will be installed.
You can also use dnf to get the list of dependencies that the package will install:
dnf repoquery --requires name_of_package_you _are_installing
system
(system)
Closed
November 9, 2025, 9:19am
5
