Installing OM and then upgrading system RAM
I am installing OM Rock on a system with only 8gb of RAM. However, tomorrow it will be getting a 64gb RAM upgrade. When I setup Rock with swap and hibernation it will build that for the 8gb that is there. Is there something I can run to get these updated for the new amount of RAM?
Disregard. Because I didn’t encrypt the drive, I just booted with a OM live session and changed the partitions manually. Should all work now when I put the new RAM in tomorrow.
