Description: When using the “encrypt” option in the installer (I use a laptop so need encryption) it appears that the encryption password is required both before the bootloader and after when you’re loading the OS. Ideally it would be preferable to only need to enter the password once.
2disbetter
(Rocking Rock 6.0 on a Framework 13 (12th Gen Intel))
2
Seems kind of nice that progress is thwarted already before the OS even gets the hand off from the bootloader. Seems more secure, doesn’t it?
